Is there something better than Vagcom?
I mostly want to monitor my engine and check for any codes, CEL, miss fires! Also where is the best place to purchase one. Thanks 🙏
If that's all you want to do there are many good OBDII "dongle" scan tool devices. But be sure you get one that caters to VAG.
example: https://www.ecstuning.com/b-schwaben...868sch01b~scf/
Or perhaps an APP-based: https://www.ecstuning.com/b-obdeleve...UaAs2FEALw_wcB
VAGCom (Ross-Tech) is more for intensive tuning and requires a PC-based laptop (you're buying the software and a cable-connector). It's far more versatile than a handheld scan tool but it would appear overkill for your needs.
Previously “CALE262”
Better, no. Cheaper, yes. I have OBD11 and Ross-tech VCDS Hex-Net Pro which is a more powerful tool but but the vast majority can get by with OBD11 just fine. There is also an iPhone app for the VCDS Hex-Net Pro which is great for logging almost any metric you wish to capture. OBD11 will work with most Android devices, I use a Samsung tablet which was ~$100 at Costco.
From Ross-Tech (re: Mac and BootCamp virtual machine):
System Requirements:
A 1.5 GHZ dual core processor with 1 Gb of RAM and Windows 7 or newer (Windows 7 through 10, but not RT) with an available USB 2.0 (or higher) port. Use a machine robust enough to properly support the operating system. Windows running inside a Virtual Machine (for example on a Mac) is not supported.Thread
herold49
03-09-2005 05:38 AM
