TTS WHICH QUATTRO SYSTEM?
#31
So Haldex can only send 100% of the torque to a particular axel only if the other axel has zero adhesion, right? And in this situation, both axel will spin a the same speed. In fact, they always spin a the same speed when they are locked together, right? When both axel have the same amount of adhesion, torque will be distributed 50/50, right?
So if I understand correctly, front/rear torque ratio is always the same as the front/rear grip ratio, correct?
#32
Conversely you've likely noted that even in Manual mode the transmission will drivetrain-protect shift down as you aggressively near redline.
