What Gear?
What Gear?
New to Audi with 2017 TT Roadster: how do I know what gear I'm in at any particular time, and is the trans supposed to find 6th, when cruising in Sport?? Thanks
In order for the gear to display you would need to make a coding change using Vag-Com or OBDEleven. While it takes longer, top gear should engage in Sport mode above a certain speed.
Concur for automatic mode but also be reminded that the current gear is annunciated when in manual transmission mode (stick moved to the right and paddles employed). "M1"... etc.
I often use Sport mode when onramp merging and then select normal mode to assure overdrive engagement for highway touring, although it would ultimately in Sport as well.
I have Vag-Com and have looked for the coding to make this change but with little luck. Do you know the require coding change or where I may find it?
"02 Auto Trans", "10-Adaptations". Set "Single gear display" to "D=On/S=On".
