TT (Mk3) Discussion Discussion forum for the Mk3 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2014- present
WHERE IS THE MAP SENOR
Old 04-08-2019, 07:17 PM
PAULDSHELTON's Avatar
Default WHERE IS THE MAP SENOR
2008 AUDI TT 3.2
Old 04-09-2019, 03:26 AM
Huey52's Avatar
You would be best served by the specific Mark forum for your 2008 (this Mark III is for 2015 and on).
Presumably you mean the Mass Air Flow sensor (MAF). If so it's in the typical location in the intake airflow routing between the air filter and the throttle body. Look for the relatively large socket with wires.
Be very careful with it, not touching the filament itself. And only use rubbing alcohol or better a dedicated MAF cleaner spray on a very lightly wiped Q-tip if significantly fouled.
Originally Posted by PAULDSHELTON
2008 AUDI TT 3.2
QuattroHawk
01-11-2006 11:50 AM
kinderutz
Audi 100 / A6 (C4 Platform)
08-22-2005 03:15 PM
Mikey L
05-16-2003 09:58 PM
kenny (dremel)
03-29-2003 07:40 PM
Quick Reply: WHERE IS THE MAP SENOR
