2004 Audi A4 11788 to 11852 Recode Question
So I'm trying to get the windows to roll up/down with the remote. I went to module 46 I think (Central Conv) and observed the value of 11788. I erased it and typed 11852 and hit recode. I can go back there now and observe that this new value is there. BTW: I did not see a "test" button or anything. Having done this, I still can't roll the windows up or down with the remote. What am I doing wrong or not doing? Do I need to start the car after recoding and drive it and then try again?
Thanks, mike |
Update: Coding set, but no value under adaptation
I believe I'm supposed to see 95 in Adaptation #62, but nothing shows up. Should I just update it with 95?
Sometimes when no value is seen under adaptation...
...it may be an indication that the ECU in question will not display the information. I have seen a few examples of this recently, where the ECU shows no value no matter what channel is accessed.
Nevertheless, I believe Mike5 has resolved this with a VAD software update. |
So far so good. Sent you an email just a little bit ago.
With a little time we'll figure out exactly what is going on!
So far...anything new?
How's that software working so far?
I just tried...just for you!
I did the VAD on a sedan from previous and I can read block 62 and others using both versions of the software. So I don't know if something weird was going on with my Palm or what (all I can point to). I will repeat this on the Avant as well to find out what happens.
Thanks, Mike |
Originally Posted by mike5
(Post 23624922)
I'm having this problem also! This is Rory by the way with the 2003 A4 1.8TQ. I recoded it to 11884 and was able to get the autolock function to work but the windows won't go up with remote when i press the lock/unlock button. Could this be because i haven't done adaption 62 with a code of 95? |
A4 Autolock function
Originally Posted by drOopy01
(Post 23742001)
Darrryl,
I'm having this problem also! This is Rory by the way with the 2003 A4 1.8TQ. I recoded it to 11884 and was able to get the autolock function to work but the windows won't go up with remote when i press the lock/unlock button. Could this be because i haven't done adaption 62 with a code of 95? Please sned me an e-mail to darryl@vadpro.com with the applicable ECU P/N and I will check the procedure. The previous example was solved with a software update. As your version is up to date, I will look at other reasons. Thanks. |
Thanks darryl will do over the weekend.
Thanks! |
