"No response from controller"
I'm using the serial port on a Dell Latitude laptop. The test seems to work, but I can't actually do anything. I'm getting "NO RESPONSE FROM CONTROLLER" whenever I try to select a control module.
Anyone know how to fix this?
Details needed:
What brand and model of hardware are you using? What version of VAG-COM. What exactly shows up when you Test on the Options screen?
Andy
Andy
Re: Details needed:
VAG COM 409-1 (though I did try an earlier version as well to no avail). The test results are for Com 3:
Port status: OK
Interface: found!
Type: Serial/Pass through
Opto/Iso: Yes
Ross-Tech Design: No
The cable is just a third-party cable that a friend is no longer using (he swears it worked on his VW). Once I get this working I'm going to buy the software and probably the kit as well.
THANKS!!
Port status: OK
Interface: found!
Opto/Iso: Yes
THANKS!!
Re: Are you using an USB/serial converter? Which control modules did you try?
No...I'm using the serial port that's built in to my laptop. I've tried the auto-scan feature as well as the individual modules for engine, transmission, locks, and radio...all have the same problem. VAG-COM makes 4 attempts and then reports "NO RESPONSE FROM CONTROLLER."
The download page of Ross-Tech say "If you're using an older SERIAL Interface based on Opto-Couplers
You'll need to use Release 311.2".
http://www.ross-tech.com/vag-com/download/index.html
