VAG-COM Discussion
Sponsored by:
Sponsored by:
'07 Q7 multiple codes and kessy fail upon picking up at paint shop..
Old 08-06-2015, 12:07 PM
jeremyshow7@gmail.com's Avatar
Default '07 Q7 multiple codes and kessy fail upon picking up at paint shop..
Hi everyone!
I just purchased the VCDS Hex-Net which I've wanted for a while. What a great tool to have.
I owned an A4 3.0 previously and got hooked on Audi which brought me to my current vehicle, a metallic light silver 2007 Q7 premium. I've only owned it for about 7 months but it has been great (for the most part) up until this past week when I took it in to get the rear right door repainted as it had rust bubbling on the lower rear corner of said door (dropped it off 9am on 7/28- picked it up 7/30 9:45am). The paint shop came highly recommended and its part of a major dealership here in my hometown. Its obvious to me that this door has had damage before and had been re-painted previously due to the rust present and some tell tale signs where the metal flake in the paint didn't lay perfectly in the lower curvature of the door panel.
Im sure there was already some type of short occurring with the circuit to the front right daytime running light as I would occasionally see the warning light pop up but the running light was always fine, then after a few minutes or hours the warning light would vanish. Also, a couple weeks prior to taking it into the paint shop, we were on our way back from a 500 mile trip when on 2 occasions I got a warning light saying the smart key wasn't recognized as being in the car (it was sitting in the ashtray cubby) and we were cruising down the highway. Both times the warning light went away after 10-30 minutes. I figured it was because the battery in the key remote was going bad. I replaced the batteries in both fobs the day after we got home.
However, The morning after returning home the car was completely dead when I went out to start it. (I've since learned about the radio issue draining the battery if the start button is pushed after the key fob exits the car and I'm sure that's what occurred as I can see it logged in the auto-scan) I jumped the car using the posts in the engine compartment and all was basically fine after that for the next 2 weeks.. except the side assist stopped working when I power-washed the car in my driveway. Im sure I got some water inside the door when I was washing the windows because I had bird poop on the front windows from parking under a tree and was trying to get it out of the window seals.
To make a long story longer, when I picked the car up from the paint shop on 7/30/2015 the kessy was not working at all. I know they removed the rear right door handle when they painted it because they told me and I noticed there was something loose inside the door so they took the car back inside and removed the inside door panel and told me there was a loose piece of foam that he forgot to attach (?) and that he forgot to re-attach the wire to the door handle.
The remote still works to lock and unlock the doors and open the rear lid but the car doesn't "see" the remotes at all (No auto-unlocking or push-to-start). I have to put the key in the ignition to start the car. This never happened before dropping it off at the paint shop. Im wondering if its possible that the oven they put the car in to quick dry the paint (140 degrees they said) could cause any probs with the electronics...? Seems 140* could happen on a hot day out in the sun on the asphalt.
I'm seeing fault codes in address 5 from the J518 access/start auth module (both 004 no signal/communication and 008 implausible) and I noticed a R135 access/start auth antenna '012 electrical fault in circuit' which occurred while it was in the shop and right about when it would have been in the oven.
The J518 fault is showing up all over the auto-scan and I understand these modules are innerconnected so that's not a surprise. I'm hoping maybe one of you folks that knows way more than me can shed some light on what I'm potentially facing here... as it goes into the Audi stealership tomorrow. I would like to not be going in completely ignorant but I'm feelin pretty dumb right now. I'm a decent mechanic (did my timing belt and cam seals on my A4 no prob) but the electronic systems I have a LOT to learn about.
Any help would be greatly appreciated and Thank YOU in advance.
Code:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 3C 42 46 47 4F
          52 55 56 61 62 65 67 6C 6D 6F 72 76 77
VIN: WA1BY74L67D052406   Mileage: 219060km-136117miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 1010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine        Labels: 03H-906-032-BLV.lbl
   Part No SW: 03H 906 032 L    HW: 03H 906 032 G
   Component: Q7 3.6-FSI-LEV2 G00 9878
   Revision: 5CH03---    Serial number:
   Coding: 0001175
   Shop #: WSC 31414 790 00001
   VCID: AB164E710A8D096653-80FE
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4L0 910 156 A    HW: 0AT 927 156
   Component: AG6 0AT 3,6 FSI USA 0040
   Revision: --H01---    Serial number:        4007105
   Coding: 0000002
   VCID: A71EB24116652D06B7-80F2
Address 03: ABS Brakes        Labels: 4L0-910-517-V1.clb
   Part No SW: 4L0 910 517 A    HW: 4L0 614 517 A
   Component: ESP ALLRAD MK25E1   0130
   Revision: 00H21001
   Coding: 0017425
   VCID: A81CB17D1B7B227EBE-80FC
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 10:45:41
             Freeze Frame:
                    Count: 128
                    Count: 12545
                    Count: 297
                    Count: 42496
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Serial number: 10601100555001
   Coding: 0000135
   VCID: E386E65122DD8126AB-80B6
   Subsystem 1 - Part No: 4F0 910 131 L
   Component: FBSAUDIC6 EZS   H45 0080
   Subsystem 2 - Part No: 4F0 910 335
   Component: FBSAUDIC6 KSG   H27 0080
   Subsystem 3 - Part No: 4F0 910 220 G
   Component: FBSAUDIC6 IDG   H01 0060
7 Faults Found:
00193 - Rear Right Door Handle Touch Sensor (G418)
            007 - Short to Ground
             Freeze Frame:
                    Fault Status: 01110111
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 219
                    Mileage: 206518 km
                    Time Indication: 0
00191 - Passenger's Door Handle Touch Sensor (G416)
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 7
                    Reset counter: 189
                    Mileage: 206561 km
                    Time Indication: 0
                    Date: 2015.01.28
                    Time: 15:35:15
             Freeze Frame:
                    Fault Status: 01111011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 124
                    Mileage: 206518 km
                    Time Indication: 0
00955 - Key 1
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00110010
                    Fault Priority: 3
                    Fault Frequency: 5
                    Reset counter: 227
                    Time Indication: 0
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 0 km
                    Time Indication: 0
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01111100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 219
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.29
                    Time: 13:44:40
02639 - Antenna Reader for Keyless Access Authorization
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 4
                    Time Indication: 0
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.lbl
   Part No SW: 4L0 910 731 F    HW: 4E0 035 729 A
   Component: Interfacebox    H43 3360
   Revision: 00000000    Serial number: 354I-067508818
   Coding: 0002003
   Subsystem 1 - Part No: 4L0 910 609
   Component: E0380 BedienteilH01 0060
   Subsystem 2 - Serial number: 00000001954691
   Subsystem 3 - Serial number: 0107.12.110000000100010749ÿ
   Subsystem 4 - Serial number: 010749ÿ
2 Faults Found:
02244 - Button in Control Head is Stuck
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 240
                    Mileage: 216968 km
                    Time Indication: 0
                    Date: 2015.07.17
                    Time: 20:59:47
             Freeze Frame:
                    Bin. Bits: 00000000
                    Bin. Bits:  0010100
                    Bin. Bits:      100
02849 - Control Module for Lane Change Assistance (J769)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 24
                    Mileage: 219048 km
                    Time Indication: 0
                    Date: 2015.08.05
                    Time: 19:47:40
Address 08: Auto HVAC        Labels: None
   Part No SW: 4L0 910 043     HW: 4L0 820 043 F
   Component: KLIMABETAETIGUNGH05 0060
   Revision: 00---012    Serial number: 00000000214634
   Coding: 0524326
   Shop #: WSC 03323 444 54047
   VCID: E18AEC5938C19336B9-80B4
Address 09: Cent. Elect.        Labels: 4F0-910-279.lbl
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Component: ILM Fahrer      H17 0240
   Revision: 00000000    Serial number: 4F0907279
   Coding: 0014123
   VCID: B12A5C1928A163B669-80E4
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H12 0080
   Coding: 00064792
   Shop #: WSC 31414
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00150059
   Shop #: WSC 31414
2 Faults Found:
00456 - Control Module for Access and Start Control (J518)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 218472 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 14:23:00
01498 - Bulb for Parking Lamps; Right (M3)
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 22
                    Mileage: 218460 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 11:29:00
Address 0E: Media Player 1        Labels: 4E0-910-111.lbl
   Part No SW: 4L0 910 111 A    HW: 4L0 035 111
   Component: CD-Changer      H41 0100
   Revision: 00000000    Serial number: AUZ5ZBF3048062
   Shop #: WSC 00000 000 00000
   VCID: 9E7097A5493FECCEC4-80CA
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 D    HW: 4E0 035 593
   Component: SDAR SIRIUS     H04 0670
   Revision: 00000000    Serial number: AUZ4Z7F3030220
1 Fault Found:
02635 - Tuner Not Enabled/Activated
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 124
                    Mileage: 206518 km
                    Time Indication: 0
                    Date: 2015.01.05
                    Time: 10:57:35
Address 15: Airbags        Labels: 4L0-910-655.lbl
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH39 0210
   Revision: 03H39000    Serial number: 0038QD039WAI
   Coding: 0014131
   Subsystem 1 - Part No: 4L0 910 339
   Component: BF-Gewichtsens. H02 0020
   Subsystem 2 - Serial number: 6332QSME1448184FK
   Subsystem 3 - Serial number: 6342QSME105331391
   Subsystem 4 - Serial number: 6352QSME10064127+
   Subsystem 5 - Serial number: 6362QSME156E326BQ
   Subsystem 6 - Serial number: 63734SME15363A3F4
   Subsystem 7 - Serial number: 63834SME116C1761.
Address 16: Steering wheel        Labels: 4F0-910-549.lbl
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H08 0230
   Revision: 00H08000    Serial number: 90025062650136
   Coding: 0002142
   VCID: E680FF45D1EFF40E4C-80B2
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: Lenkradmodul    H07 0090
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 218475 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 14:23:58
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4L0 920 980 H
   Component: KOMBIINSTR. M73 H17 0240
   Revision: 00600000    Serial number: 5HH7AE2A6
   Coding: 2641263
   Shop #: WSC 40621 001 1048576
   VCID: A306A651625DC126EB-80F6
Address 19: CAN Gateway        Labels: 4L0-910-468.lbl
   Part No SW: 4L0 910 468     HW: 4L0 907 468 A
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0800D0682880D4
   Coding: F5D7FE77347A02
   Shop #: WSC 06120 444 59081
   VCID: EC948D6DCF03CE5E1A-80B8
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 218475 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 14:23:58
Address 36: Seat Mem. Drvr        Labels: None
   Part No SW: 4F0 910 760     HW: 4L0 959 760
   Component: Sitzmemory FS   H01 0100
   Revision: 00000000    Serial number: 00000000896401
   Coding: 0082954
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 218460 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:38
Address 37: Navigation        Labels: 4E0-910-88x-37.lbl
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 D
   Component: MNS US          H48 1100
   Revision: 00000000    Serial number: 313IQ067506464
   VCID: B83C613DCBDBB2FE2E-80EC
Address 3C: Lane Change        Labels: None
   Part No SW: 4L0 910 566 A    HW: 4L0 907 566 A
   Component: J0769_SWA_MasterH06 0060
   Revision: 00H06000    Serial number: 6PZ 009 014-00
   Coding: 0000001
   VCID: AC144D6D0F830E5E5A-80F8
   Subsystem 1 - Part No: 4L0 910 568 A
   Component: J0770_SWA_Slave_H05 0060
   Subsystem 2 - Serial number: 6PZ 009 014-20
   Subsystem 3 - Serial number: 3F21.09.0600H0500000010045ÿ
   Subsystem 4 - Serial number: 010045ÿ
1 Fault Found:
02852 - Indicator Lamp for Lane Change Assistance (K232)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 239
                    Mileage: 217152 km
                    Time Indication: 0
                    Date: 2015.07.21
                    Time: 08:57:31
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0130
   Revision: 00000000    Serial number: ’u
   Coding: 0051915
   VCID: AF2E5A613E9575467F-80FA
5 Faults Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 3
                    Fault Frequency: 254
                    Reset counter: 20
                    Mileage: 206518 km
                    Time Indication: 0
                    Date: 2015.01.05
                    Time: 11:20:18
02123 - Door Warning Light / Entry Light
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 243
                    Mileage: 217155 km
                    Time Indication: 0
                    Date: 2015.07.21
                    Time: 08:57:57
01705 - Selection Switch for Mirror-Adjust (E48)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 243
                    Mileage: 217155 km
                    Time Indication: 0
                    Date: 2015.07.21
                    Time: 08:58:57
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:38
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:38
Address 46: Central Conv.        Labels: 4L0-910-289.lbl
   Part No SW: 4L0 910 289 D    HW: 4L0 907 289 A
   Component: Komfortgeraet   H05 0020
   Revision: 0020 ---    Serial number: 01020555590000
   Coding: 7632925
   Subsystem 1 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 218475 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 14:24:05
Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
   Part No SW: 4L0 910 223 D    HW: 4L0 035 223 A
   Component: DSP-High AU716  H02 0110
   Revision: PROD_01     Serial number: 00000000103084
   Coding: 0000026
   Shop #: WSC 03323 444 12191
   VCID: A502B8496C693F1685-80F0
Address 4F: Centr. Electr. II        Labels: 4F0-910-280.lbl
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000042567
   Coding: 0012001
   VCID: DEF0D7A509BFACCE84-808A
2 Faults Found:
02072 - Control Module for Energy Management (J644)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 218460 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 10:17:00
             Freeze Frame:
                    Voltage: 12.100 V
                    Temperature: 77.0°C
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 5
                    Mileage: 218460 km
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 12.300 V
                    Temperature: 77.0°C
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0130
   Revision: 00-00000
   Coding: 0051915
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 243
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:39
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:39
Address 55: Headlight Range        Labels: 4F0-910-357.lbl
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Component: AFS 1           H01 0020
   Revision: 00000001    Serial number:
   Coding: 0000021
   VCID: A91AB47900711B76A1-80FC
   Subsystem 1 - Part No: 7L6 941 329 A
   Component: AFS-Modul links H06 0002
   Subsystem 2 - Part No: 7L6 941 329 A
   Component: AFS-Modul rechtsH06 0002
Address 56: Radio        Labels: 4E0-910-541.lbl
   Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 P
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 388I-067557132
   Coding: 0000002
   VCID: AE104765399F7C4E74-80FA
2 Faults Found:
00532 - Supply Voltage B+
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 23
                    Mileage: 216549 km
                    Time Indication: 0
                    Date: 2015.07.15
                    Time: 07:31:30
00446 - Function Limitation due to Under-Voltage
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 86
                    Reset counter: 23
                    Mileage: 216549 km
                    Time Indication: 0
                    Date: 2015.07.15
                    Time: 06:08:58
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4L0 910 181     HW: 4L0 915 181
   Component: J0644 BEM       H12 0530
   Revision: --------    Serial number: 00000000048608
   Shop #: WSC 06120 444 82974
   VCID: E484E54D27D3861E52-80B0
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  0609281784
   Coding: 344630393135313035442056413030363039323831373834
2 Faults Found:
03041 - Energy Management Active
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 29
                    Reset counter: 255
                    Mileage: 206518 km
                    Time Indication: 0
                    Date: 2015.01.05
                    Time: 11:13:58
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:37
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Component: TSG HL          H21 0050
   Coding: 0051722
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:38
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:38
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.lbl
   Part No SW: 4F0 910 273 B    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0100
   Revision: 00050100    Serial number: 00000700031249
   Coding: 0062424
   VCID: A208A3557D47C82EE0-80F6
1 Fault Found:
            004 - No Signal/Communication - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100100
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:46
             Freeze Frame:
                    (no units): 0.0
                    Voltage: 12.40 V
                    (no units): 33.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
Address 67: Voice Control        Labels: 4E0-910-75x-67.lbl
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H45 0630
   Revision: 00000000    Serial number: 00000609210232
   Shop #: WSC 12336 024 394758
   VCID: B424550DD7B3569E02-80E0
Address 6C: Back-up Cam.        Labels: 4L0-910-441.clb
   Part No SW: 4L0 910 441 A    HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J6941RV
   Coding: 1001101
   VCID: A404A54D6753C61E92-80F0
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 4L0 910 945     HW: 4L0 827 851 B
   Component: ValeoHeckdeckel H21 0280
   Revision: --H21001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   Subsystem 1 - Part No: 4L0 910 946
   Subsystem 2 - Serial number: E5030100B
   Subsystem 3 - Serial number: RD29.09.06--H21001001C0217ÿ
   Subsystem 4 - Serial number: 1C0217ÿ
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 4
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:37
Address 6F: Centr. Conv. II        Labels: None
   Part No HW: 4L0 907 290 A
   Revision: AAH05061    Serial number: 002035426-----
   VCID: D5E2C8893C896F96D5-8080
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:37
00927 - Terminal 30 (Right)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 10:09:58
01516 - Terminal 30; Left
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 10:09:58
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Component: TSG HR          H21 0050
   Coding: 0051722
3 Faults Found:
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 239
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:38
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:38
Address 76: Park Assist        Labels: 4Fx-910-283.lbl
   Part No SW: 4F0 910 283 F    HW: 4F0 919 283 F
   Component: Parkhilfe 4-Kan H09 0060
   Revision: 00H09000    Serial number: 06230626204537
   Coding: 0021246
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 3
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 3
                    Fault Frequency: 28
                    Reset counter: 160
                    Mileage: 206518 km
                    Time Indication: 0
                    Date: 2015.01.05
                    Time: 11:20:14
Address 77: Telephone        Labels: 4E0-910-336.lbl
   Part No SW: 4F0 910 336 H    HW: 4E0 862 335
   Component: Handyvorb2      H16 1130
   Revision: 00000000    Serial number: 00000007571933
   Coding: 0010900
End-------------------------(Elapsed Time: 03:37)--------------------------
Old 09-22-2015, 07:48 AM
michael tsampis's Avatar
Originally Posted by jeremyshow7@gmail.com
Hi everyone!
Code:
   Coding: 0001175
   Coding: 0000002
   Revision: 00H21001
   Coding: 0017425
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 10:45:41
             Freeze Frame:
                    Count: 128
                    Count: 12545
                    Count: 297
                    Count: 42496
   Coding: 0000135
7 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 219
                    Mileage: 206518 km
                    Time Indication: 0
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 7
                    Reset counter: 189
                    Mileage: 206561 km
                    Time Indication: 0
                    Date: 2015.01.28
                    Time: 15:35:15
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 124
                    Mileage: 206518 km
                    Time Indication: 0
00955 - Key 1
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 5
                    Reset counter: 227
                    Time Indication: 0
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 219
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.29
                    Time: 13:44:40
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 4
                    Time Indication: 0
   Coding: 0002003
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 240
                    Mileage: 216968 km
                    Time Indication: 0
                    Date: 2015.07.17
                    Time: 20:59:47
             Freeze Frame:
                    Bin. Bits: 00000000
                    Bin. Bits:  0010100
                    Bin. Bits:      100
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 24
                    Mileage: 219048 km
                    Time Indication: 0
                    Date: 2015.08.05
                    Time: 19:47:40
   Coding: 0524326
   Coding: 0014123
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 218472 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 14:23:00
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 22
                    Mileage: 218460 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 11:29:00
1 Fault Found:
            000 -  -
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 124
                    Mileage: 206518 km
                    Time Indication: 0
                    Date: 2015.01.05
                    Time: 10:57:35
   Coding: 0014131
   Coding: 0002142
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 218475 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 14:23:58
   Coding: 2641263
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 218475 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 14:23:58
   Coding: 0082954
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 218460 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:38
   Coding: 0000001
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 239
                    Mileage: 217152 km
                    Time Indication: 0
                    Date: 2015.07.21
                    Time: 08:57:31
   Coding: 0051915
5 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Reset counter: 20
                    Mileage: 206518 km
                    Time Indication: 0
                    Date: 2015.01.05
                    Time: 11:20:18
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 243
                    Mileage: 217155 km
                    Time Indication: 0
                    Date: 2015.07.21
                    Time: 08:57:57
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 243
                    Mileage: 217155 km
                    Time Indication: 0
                    Date: 2015.07.21
                    Time: 08:58:57
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:38
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:38
   Coding: 7632925
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 218475 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 14:24:05
   Coding: 0000026
   Coding: 0012001
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 218460 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 10:17:00
             Freeze Frame:
                    Voltage: 12.100 V
                    Temperature: 77.0°C
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 5
                    Mileage: 218460 km
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 12.300 V
                    Temperature: 77.0°C
   Revision: 00-00000
   Coding: 0051915
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 243
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:39
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:39
   Coding: 0000021
   Coding: 0000002
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 23
                    Mileage: 216549 km
                    Time Indication: 0
                    Date: 2015.07.15
                    Time: 07:31:30
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 86
                    Reset counter: 23
                    Mileage: 216549 km
                    Time Indication: 0
                    Date: 2015.07.15
                    Time: 06:08:58
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 29
                    Reset counter: 255
                    Mileage: 206518 km
                    Time Indication: 0
                    Date: 2015.01.05
                    Time: 11:13:58
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:37
   Coding: 0051722
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:38
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:38
   Coding: 0062424
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:46
             Freeze Frame:
                    (no units): 0.0
                    Voltage: 12.40 V
                    (no units): 33.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 1001101
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 4
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:37
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 3
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:37
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 10:09:58
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 10:09:58
   Coding: 0051722
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 239
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:38
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
                    Date: 2015.07.30
                    Time: 09:45:38
   Coding: 0021246
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 3
                    Reset counter: 5
                    Mileage: 218461 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 28
                    Reset counter: 160
                    Mileage: 206518 km
                    Time Indication: 0
                    Date: 2015.01.05
                    Time: 11:20:14
   Coding: 0010900
Did you ever find what the problem was i have a similar problem with my 2006 a6
chinpark
Q5/SQ5 MKI (8R) Discussion
07-17-2015 04:40 PM
schnellmb
Auto Detailing Discussion
10-28-2008 03:16 PM
garlicTTown
12
04-10-2004 04:23 PM
christopherjs
01-21-2003 06:54 AM
Levent
9
08-15-2002 11:02 PM
Quick Reply: '07 Q7 multiple codes and kessy fail upon picking up at paint shop..
