2001 Audi tt a little assistance please
2001 Audi tt quatroI
I had the timing chain tensioner mess up and ended up putting another head in with a new chain, tensioner and belt. She ran great for the first three days, but on the third day died as I was pulling up to a traffic light. I now have a crank but no start issue.
I did a visual on the cam position sensor because it was showing a problem code and replaced the sensor because the old one had some cracks on the interior plastic, but the code still pops up and I still have the no start.
Any assistance is greatly appreciated.
Thursday,21,March,2019,19:25:32:35742
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: TRUUT28N811010636 License Plate: 0137QB
Mileage: 1,000 Repair Order: 1
Chassis Type: 8N (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Address 01: Engine Labels: 06A-906-032-AMU.lbl
Part No: 8N0 906 018 K
Component: 1.8L R4/5VT G 0003
Coding: 06710
Shop #: WSC 01236
VCID: 392F2F57C0412B2F993-5118
TRUUT28N811010636 AUZ5Z0Y8013031
7 Faults Found:
16486 - Mass Air Flow Sensor (G70)
P0102 - 35-10 - Signal too Low - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16685 - Cylinder 1
P0301 - 35-10 - Misfire Detected - Intermittent
16687 - Cylinder 3
P0303 - 35-10 - Misfire Detected - Intermittent
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
16686 - Cylinder 2
P0302 - 35-10 - Misfire Detected - Intermittent
17695 - Boost Pressure Control Valve (N249)
P1287 - 35-10 - Open Circuit - Intermittent
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.clb
Part No: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18446
Shop #: WSC 01236
VCID: 3E253C4BD96F0C17AC1-4AE0
No fault code found.
Address 08: Auto HVAC Labels: 8N0-820-043.lbl
Part No: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00140
Shop #: WSC 01236
VCID: 2809FA132BEBA2A7F6D-2578
2 Faults Found:
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
01582 - Signal for Coolant Temperature
Address 15: Airbags Labels: 8N8-909-601.lbl
Part No: 8N8 909 601
Component: Airbag Front+Seite 2008
Coding: 10103
Shop #: WSC 05244
VCID: 77ABE96FB6D5FD5FAF7-5160
7 Faults Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
31-10 - Open or Short to Ground - Intermittent
01217 - Side Airbag Igniter; Driver Side (N199)
32-10 - Resistance Too High - Intermittent
00591 - Seat Belt Switch; Driver (E24)
30-10 - Open or Short to Plus - Intermittent
00592 - Seat Belt Switch; Passenger (E25)
01218 - Side Airbag Igniter; Passenger Side (N200)
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 8Nx-920-xxx-17.lbl
Part No: 8N1 920 930 J
Component: KOMBI+WEGFAHRS. M73 D53
Coding: 07244
Shop #: WSC 00222
VCID: 38292A53FB4B322766D-4AE0
12 Faults Found:
01039 - Coolant Temperature Sensor (G2)
29-10 - Short to Ground - Intermittent
00771 - Fuel Level Sensor (G)
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
01128 - Immobilizer Pickup Coil (D2)
35-10 - - - Intermittent
01176 - Key
01179 - Incorrect Key Programming
35-00 - -
00562 - Sensor for Oil Level/Temperature (G266)
00668 - Supply Voltage Terminal 30
53-10 - Supply Voltage Too Low - Intermittent
01312 - Powertrain Data Bus
37-10 - Faulty - Intermittent
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
VCID: 1F1BE1CF7EA5651F877-4AE0
1 Fault Found:
00-00 - -
Address 35: Centr. Locks Labels:. 8Nx-962-267.lbl
Part No: 8N7 962 267 A
Component: Central Lock/Alarm D04
Coding: 15884
Shop #: WSC 01236
VCID: 3E253C4BD96F0C17AC1-4EC8
5 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00956 - Key 2
09-10 - Adaptation Limit Surpassed - Intermittent
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8N7 951 177
Component: Innenraumueberw. D14
Coding: 00001
Shop #: WSC 00000
VCID: 7BA3F55F8AFDD93FCBF-50D0
3 Faults Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
43-00 - Closed
81-00 - Open
01462 - Anti-theft alarm ultra sonic Sensor (G209)
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 8N0 035 186 A
Component: Radio D05
Coding: 00017
Shop #: WSC 01236
VCID: 2E050C0B090FFC973C1-4A84
End----(Elapsed Time: 02:49, VBatt start/end: 12.2V/12.3V. VIgn 0.0V)------
Coding: 06710
Shop #: WSC 01236
Coding: 18446
Shop #: WSC 01236
Coding: 10103
Shop #: WSC 05244
7 Faults Found:
Coding: 07244
Shop #: WSC 00222
12 Faults Found:
01176 - Key
35-00 - -
1 Fault Found:
00-00 - -
Coding: 15884
Shop #: WSC 01236
5 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
Coding: 00001
Shop #: WSC 00000
3 Faults Found:
43-00 - Closed
81-00 - Open
Coding: 00017
Shop #: WSC 01236
End----------(Elapsed Time: 02:43, VBatt start/end: 12.4V/12.3V)-----------
VCDS Release 18.9.1: SRI Reset
Control Module Part Number: 8N1 920 930 J Labels: 8Nx-920-xxx-17.lbl
Component:KOMBI+WEGFAHRS. M73 D53, Coding:07244
Operation: Please select an operation
Channel Description Unit Current val. New val.
02 Service Reminder Status 1 ---
40 Mileage since Service DIST x100 0 ---
41 Time since Service Days 1032 ---
42 Min Mileage to Service DIST x1000 10 ---
43 Max Mileage to Service DIST x1000 10 ---
44 Max Time to Service Days 365 ---
45 Oil Quality 1 ---
46 Total Consumption DIST x100 1260 ---
www.Ross-Tech.com
Coding: 06710
Shop #: WSC 01236
7 Faults Found:
16685 - Cylinder 1
16687 - Cylinder 3
16686 - Cylinder 2
Coding: 18446
Shop #: WSC 01236
Coding: 00140
Shop #: WSC 01236
2 Faults Found:
Coding: 10103
Shop #: WSC 05244
7 Faults Found:
Coding: 07244
Shop #: WSC 00222
12 Faults Found:
01176 - Key
35-00 - -
1 Fault Found:
00-00 - -
Coding: 15884
Shop #: WSC 01236
5 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
Coding: 00001
Shop #: WSC 00000
3 Faults Found:
43-00 - Closed
81-00 - Open
Coding: 00017
Shop #: WSC 01236
Coding: 06710
Shop #: WSC 01236
Coding: 18446
Shop #: WSC 01236
Coding: 10103
Shop #: WSC 05244
7 Faults Found:
Coding: 07244
Shop #: WSC 00222
12 Faults Found:
01176 - Key
35-00 - -
1 Fault Found:
00-00 - -
Coding: 15884
Shop #: WSC 01236
5 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
Coding: 00001
Shop #: WSC 00000
3 Faults Found:
43-00 - Closed
81-00 - Open
Coding: 00017
Shop #: WSC 01236
Oops attached an old log file here is the latest
Tuesday,04,June,2019,02:46:36:35742
www.Ross-Tech.com
VIN: TRUUT28N811010636 License Plate: 01370B
Mileage: Repair Order: 06032019
Coding: 06710
Shop #: WSC 01236
2 Faults Found:
16496 - Intake Air Temp. Sensor (G42)
P0112 - 35-00 - Signal too Low
16725 - Camshaft Position Sensor (G40)
P0341 - 35-00 - Implausible Signal
Coding: 18446
Shop #: WSC 01236
Coding: 00140
Shop #: WSC 01236
VCID: 2809FA132BEBA2A7F6D-2580
Coding: 10103
Shop #: WSC 05244
7 Faults Found:
Coding: 07244
Shop #: WSC 00222
7 Faults Found:
35-00 - -
2 Faults Found:
00-00 - -
07-00 - Signal too Low
Coding: 15884
Shop #: WSC 01236
VCID: 3E253C4BD96F0C17AC1-4EEA
7 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
01560 - Passenger Door
59-00 - Can't Unlock
Coding: 00001
Shop #: WSC 00000
VCID: 7BA3F55F8AFDD93FCBF-50F4
2 Faults Found:
81-00 - Open
Coding: 00017
Shop #: WSC 01236
2 Faults Found:
00855 - Connection to CD changer
End----------(Elapsed Time: 02:50, VBatt start/end: 14.3V/14.3V)-----------
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 35: DTCs cleared
Address 45: DTCs cleared
Coding: 06710
Shop #: WSC 01236
2 Faults Found:
Coding: 18446
Shop #: WSC 01236
Coding: 00140
Shop #: WSC 01236
Coding: 10103
Shop #: WSC 05244
7 Faults Found:
Coding: 07244
Shop #: WSC 00222
7 Faults Found:
35-00 - -
2 Faults Found:
00-00 - -
Coding: 15884
Shop #: WSC 01236
Coding: 00001
Shop #: WSC 00000
Coding: 00017
Shop #: WSC 01236
2 Faults Found:
www.Ross-Tech.com
Coding: 06710
Shop #: WSC 01236
2 Faults Found:
Coding: 18446
Shop #: WSC 01236
Coding: 00140
Shop #: WSC 01236
Coding: 10103
Shop #: WSC 05244
7 Faults Found:
Coding: 07244
Shop #: WSC 00222
7 Faults Found:
35-00 - -
2 Faults Found:
00-00 - -
Coding: 15884
Shop #: WSC 01236
7 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
Coding: 00001
Shop #: WSC 00000
2 Faults Found:
81-00 - Open
Coding: 00017
Shop #: WSC 01236
2 Faults Found:
Coding: 06710
Shop #: WSC 01236
2 Faults Found:
Coding: 18446
Shop #: WSC 01236
Coding: 00140
Shop #: WSC 01236
Coding: 10103
Shop #: WSC 05244
7 Faults Found:
Coding: 07244
Shop #: WSC 00222
7 Faults Found:
35-00 - -
2 Faults Found:
00-00 - -
Coding: 15884
Shop #: WSC 01236
Coding: 00001
Shop #: WSC 00000
Coding: 00017
Shop #: WSC 01236
2 Faults Found:
fezzyboy
08-16-2012 06:09 AM
NickS
03-20-2003 01:42 PM
ride
Wheels & Tires Discussion
08-19-2002 10:25 AM
