2018 RS3 Lane change assist code, unable to clear it.
have an odd issue. I think I enabled something I shouldn't have now I am not able to revert back. My RS3 doesn't have lane assist but does have blindspot detection. I am not able to turn off the lane assist and clear the code. Nothin I do works. Anyone have any suggestions? Here is the log file
Monday,20,November,2017,16:48:50:28124
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
Ross-Tech: Home
Chassis Type FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 3C 42 44 47 52 5F
6C BB BC
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (------DAZA) Labels: None
Part No SW: 8V0 907 404 G HW: 07K 907 309 E
Component: 2.5l R5/4V TF H22 0002
Revision: 53H22000
Coding: 0A250032242600053620
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM25TFS0118V0907404G 001002
ROD: EV_ECM25TFS0118V0907404G.rod
VCID: 3D7AE86DAC1C72AEA1-8068
No fault code found.
Readiness: 1110 0101
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0DL 300 012 H HW: 0GC 927 711 G
Component: GSG DQ500 H06 2112
Revision: 00H06V07
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_001_VW36.rod
VCID: 2E58DF21717A993628-807A
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 8V0 614 517 C HW: 8V0 614 517 C
Component: ESC H25 0621
Revision: 00000000 Serial number: 61897000000824
Coding: 2EAA6B7DD4990BAA89970B6681966974D62BD091D081963602 4150D4828812
ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
ROD: EV_Brake1UDSContiMK100IPB_035_AU37.rod
VCID: 3972FC7DB8344E8E8D-806C
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0448153803
Coding: 030C0C
ASAM Dataset: EV_KessyHellaMQBAB 002020
ROD: EV_KessyHellaMQBAB_002_VW37.rod
VCID: 3C7CE569B7067BA696-8068
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 Q HW: 8V0 820 043 Q
Component: AC Automat H03 0130
Revision: 20002000 Serial number: 00000001297266
Coding: 03000015010000000000000000001400
ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 40849199DBEE1F46CA-8014
Relative humidity sensor in fresh air intake duct:
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: 4C00D8B800PAG0MUFU03
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 085 BN HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H36 0253
Serial number: 01001721200247
Coding: 00000000000000000000000000000000000000000000000000 0000000000
ASAM Dataset: EV_BCMMQB 018001
ROD: EV_BCMBOSCH_018.rod
VCID: 06084781B94AF176B0-8052
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 170608 043 0585
Serial number: 170628031212
Coding: 0A47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 62938507
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 18 03 2017 00002218
Alarm horn:
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000070231710
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST001P0PAP00000
Coding: 101F00
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Component: PDC 8 KanalH07 0044
Serial number: 000308418617194
Coding: 0470151011
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_EPHVA18AU3700000 009035
ROD: EV_EPHVA18AU3700000.rod
VCID: 4B9EB6B5E2A8CC1E2F-801E
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 G HW: 8V0 907 376 F
Component: DAEMPFUNGS-SG H11 0082
Serial number: 100517004
ASAM Dataset: EV_AudiMagneRide 002008
ROD: EV_AudiMagneRide_002_AU37.rod
VCID: 458A808DC4CC3A6EF9-8010
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR08HMAT
Coding: 9DFCFCC0008000005000001AC24800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002144
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 47968A85FEC0287E0B-8012
Belt Pretensioner left:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H37 0350
Serial number: 34258931A11071740072
Coding: 333135
Belt Pretensioner right:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H37 0350
Serial number: 34258932A12071750003
Coding: 333135
Occupant Detection:
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 694000000000001MP2XG
Coding: 303337
Side Sensor Driver Front:
Subsystem 4 - Part No SW: ----------- HW: 480 000 308 17
Component: SideSensor_Df 001 0887
Serial number: 35700000000F0988172M
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 5 - Part No SW: ----------- HW: 480 000 308 17
Component: SideSensor_Pf 001 0887
Serial number: 35800000000EF888172-
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 6 - Part No SW: ----------- HW: 480 400 307 17
Component: SideSensor_Dr 000 6149
Serial number: 35100019D2600D5525D/
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 7 - Part No SW: ----------- HW: 480 400 407 17
Component: SideSensor_Pr 000 6149
Serial number: 3520001A125F5886B499
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 8 - Part No SW: ----------- HW: 480 402 306 17
Component: FrontSensor_D 001 6149
Serial number: 35500029B24F3854A112
Coding: 2D2D2D
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 402 306 17
Component: FrontSensor_P 001 6149
Serial number: 35600029B24F3855F119
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 KK HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0140
Revision: -------- Serial number: 17071704400386
Coding: 2018
ASAM Dataset: EV_SMLSKLOMQB 020002
ROD: EV_SMLSKLOMQB_020_AU37.rod
VCID: 0D1A78ADDC3C822EF1-8058
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 8V0 920 890 A HW: 8V0 920 890 A
Component: FBenUSA H16 0066
Coding: 086D18533B88CF050204EC041800001000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001027
ROD: EV_DashBoardFPKAU37X.rod
VCID: 3B7EE675B2087C9E9F-806E
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 27061710803012
Coding: 03010004340860005B00802EB80B0000000101000000000000 0000000000
ASAM Dataset: EV_GatewNF 013023
ROD: EV_GatewNF_VW27.rod
VCID: 336ECE559A58B4DE47-8066
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20170726152456 22093
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Component: J367-BDMHella H10 9070
Serial number: 9960034404
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 K HW: 0CQ 525 130
Component: Haldex4Motion H52 7762
Serial number: HA1-00009.06.17
Coding: 0601
ASAM Dataset: EV_AllWheelContrHA1VW37X 002015
ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
VCID: 4D9AB8AD1CBCC22E31-8018
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000203468008
Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB_004_VW37.rod
VCID: 346CCD499F56B3E65E-8060
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 3Q0 907 566 F HW: 3Q0 907 566
Component: MRR1Rear H21 0610
Revision: --------
Coding: 04C002
ASAM Dataset: EV_RearRadarS1BoschVW48X 001007
ROD: EV_RearRadarS1BoschVW48X.rod
3 Faults Found:
729349 - Control Module for Lane Change Assistance
C1114 54 [009] - Missing Calibration / Basic Setting
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 84
Mileage: 3498 km
Date: 2017.11.20
Time: 16:35:50
Control Module temperature: 33 ∞C
Voltage terminal 30: Measured value not available
Vehicle speed: 0.00 km/h
Terminal 15 status: Measured value not available
Voltage terminal 15: 11.80 V
729605 - Control Module 2 for Lane Change Assistance
C1115 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 84
Mileage: 3498 km
Date: 2017.11.20
Time: 16:35:50
1192264 - Databus
U1123 00 [009] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 84
Mileage: 3498 km
Date: 2017.11.20
Time: 16:35:50
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 240517EEO19082
Coding: 005D1B205C00048000000002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
VCID: 438E9E95CAF8045ED7-8016
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8106
ASAM Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013_VW37.rod
VCID: 3A70E371BD32459684-806E
Address 47: Sound System (J525) Labels:* None
Part No SW: 81A 035 466 B HW: 81A 035 466
Component: MIB2_amp_P_A3 H10 0440
Revision: 00000001 Serial number: AUZ8ZAH5F00MJ1Z
Coding: 0173030000AAAA2AAA0000010000
ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
ROD: EV_AMPMst16C9Gen2ALPI.rod
VCID: 244C3D092FB62366CE-8070
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 300617EFT39127
Coding: 005D13205E00048000000002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
VCID: 42809B91D5E20D56DC-8016
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 8V1 035 880 B HW: 8V1 035 880
Component: MU-P-LNS-US 054 1110
Serial number: A702H0H2502424
Coding: 017361020000000011220002041A00102F0028E5017001047E
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_AU37.rod
Data medium:
Subsystem 1 - Part No SW: V03 959 801 GH HW: -----------
Component: NAR 2017/2018 --- 0060
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9H1Y04NFT
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BK HW: 8V0 919 614 BK
Component: ControlUnit_H H85 0855
Serial number: ALJAL125051700050683
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 3012
Address 6C: Back-up Cam. (J772) Labels: 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H12 0231
Coding: 0273010102002001400040
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 200617EFK03358
Coding: 000C13204000048000000002
ASAM Dataset: EV_DCURearDriveMINKLO 006003
ROD: EV_DCURearDriveMAXCONT_VW37.rod
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0041
Serial number: 200617EFK03351
ASAM Dataset: EV_DCURearPasseMINKLO 006003
ROD: EV_DCURearPasseMAXCONT_VW37.rod
End-------------------------(Elapsed Time: 06:10)--------------------------
Ross-Tech: Home
6C BB BC
Revision: 53H22000
Revision: 00H06V07
Coding: 0014
Coding: 030C0C
Coding: 0A47F7
Coding: 00006C
Light switch:
Alarm horn:
Sun Roof:
Coding: 101F00
Coding: 0470151011
Coding: 333135
Coding: 333135
Occupant Detection:
Coding: 303337
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2018
Alternator:
Coding: 0601
Revision: --------
Coding: 04C002
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 84
Mileage: 3498 km
Date: 2017.11.20
Time: 16:35:50
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 84
Mileage: 3498 km
Date: 2017.11.20
Time: 16:35:50
1192264 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 84
Mileage: 3498 km
Date: 2017.11.20
Time: 16:35:50
Coding: 8106
Data medium:
Danielfive5
06-12-2019 11:04 AM
Chintan Bhatt
A4 (B8 Platform) Discussion
10-31-2016 06:45 PM
