A6 C6 electric supply problem, what could be the cause?
Hi Guys,
My car wasn't really used for 2-3 months, when I came back the battery started to act weak, had to charge every few days, at the end electric consumers started to shut off such as the air suspension, window washer pump, head lights didn't remain on, electric trunk wouldn't open in a matter of 2 days so many problems came out i was sure the battery is not strong enough, I took it to the mechanic to get a new factory recommended battery in it. After changing the problem still existed, and he found that the car is not getting sufficient charge, so took out the generator and refurbished it in a professiona shop with 2 years of warranty They put back the generator and all the problems seemed to be solved they thought the car was done when suddenly all the problems came back vagcom also started to show up many error messages. The guy said he doesn't understand what happened and worked late on it but couldn't finish, will continue on Monday. But I think for now he also doesnt know whats the source. I am thinking maybe one of the power supply relays have problem. Any ideas what could be causing this? Common problems? Thanks a lot in advance
biriger2
04-15-2018 05:09 AM
