S5 with MIL, EPC, TPMS.... Multiple "Short to Ground"
I've got a 2010 S5 that shortly after starting the other day proclaimed multiple faults. Stabilization System Fault, TPMS Malfunction, Parking Brake Malfunction and the MIL light for good measure. It runs but has a misfire at idle and stumbles under acceleration. VAG-COM shows multiple sensors with most being "Short to Ground" or "Supply Voltage" The battery was the original so I swapped for a new one today, cleared the codes, checked fuses but the problem persists. Seems electrical to me. Anyone know the common failure point here?
15 Faults Found:
008853 - Fuel Pressure Regulator Valve (N276)
P2295 - 002 - Short to Ground
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 10:55:27
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 27.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.065 V
004764 - Fuel Pressure Regulator Valve; Bank 2 (N276)
P129C - 002 - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 10:55:27
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 27.0°C
Voltage: 12.065 V
005494 - Right Engine Mount Solenoid Valve (N145)
P1576 - 002 - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:21
Freeze Frame:
RPM: 208 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 26.0°C
Voltage: 10.922 V
005490 - Left Engine Mount Solenoid Valve (N144)
P1572 - 002 - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:21
Freeze Frame:
RPM: 208 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 26.0°C
Voltage: 10.922 V
001112 - Evap System Purge Control Valve (N80)
P0458 - 002 - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:21
Freeze Frame:
RPM: 208 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 26.0°C
Voltage: 10.922 V
004199 - Intake Air Switch-Over Valve (N335)
P1067 - 002 - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:21
Freeze Frame:
RPM: 208 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 26.0°C
Voltage: 10.922 V
005173 - Secondary Air Pump Relay (J299)
P1435 - 002 - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:21
Freeze Frame:
RPM: 208 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 26.0°C
Voltage: 10.922 V
005153 - Secondary Air Injection Solenoid Valve (N112)
P1421 - 002 - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:21
Freeze Frame:
RPM: 208 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 26.0°C
Voltage: 10.922 V
000256 - Mass Air Flow Sensor (G70)
P0100 - 002 - Supply Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:22
Freeze Frame:
RPM: 1964 /min
Load: 24.7 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 26.0°C
Voltage: 11.557 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 001 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:22
Freeze Frame:
RPM: 1838 /min
Load: 15.7 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 26.0°C
Voltage: 11.557 V
P1653 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:22
Freeze Frame:
RPM: 1838 /min
Load: 15.7 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 26.0°C
Voltage: 11.557 V
P0100 - 004 - Supply Voltage
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:23
Freeze Frame:
RPM: 1206 /min
Load: 22.7 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 26.0°C
Voltage: 11.684 V
000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0030 - 004 - Malfunction / Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:27
Freeze Frame:
RPM: 1209 /min
Load: 29.0 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 25.0°C
Voltage: 12.954 V
000080 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit
P0050 - 004 - Malfunction / Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:27
Freeze Frame:
RPM: 1209 /min
Load: 29.0 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 25.0°C
Voltage: 12.954 V
009217 - EVAP Leak Detection Pump Control Circuit
P2401 - 002 - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:31
Freeze Frame:
RPM: 1053 /min
Load: 25.1 %
Speed: 0.0 km/h
Temperature: 32.0°C
Temperature: 25.0°C
Voltage: 13.208 V
Readiness: 0110 1101
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0060
Revision: -------- Serial number: --------------
Coding: 110D18
Shop #: WSC 02132 444 14684
VCID: 020081E89D75632E4B-8056
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 231
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:23
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x0026
Hex Value: 0x4693
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 231
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:24
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x62A2
Hex Value: 0x0032
Hex Value: 0x0294
Hex Value: 0x00FF
15 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 10:55:27
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 27.0°C
Voltage: 12.065 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 10:55:27
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 27.0°C
Voltage: 12.065 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:21
Freeze Frame:
RPM: 208 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 26.0°C
Voltage: 10.922 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:21
Freeze Frame:
RPM: 208 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 26.0°C
Voltage: 10.922 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:21
Freeze Frame:
RPM: 208 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 26.0°C
Voltage: 10.922 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:21
Freeze Frame:
RPM: 208 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 26.0°C
Voltage: 10.922 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:21
Freeze Frame:
RPM: 208 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 26.0°C
Voltage: 10.922 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:21
Freeze Frame:
RPM: 208 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 26.0°C
Voltage: 10.922 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:22
Freeze Frame:
RPM: 1964 /min
Load: 24.7 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 26.0°C
Voltage: 11.557 V
P1653 - 001 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:22
Freeze Frame:
RPM: 1838 /min
Load: 15.7 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 26.0°C
Voltage: 11.557 V
P1653 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:22
Freeze Frame:
RPM: 1838 /min
Load: 15.7 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 26.0°C
Voltage: 11.557 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:23
Freeze Frame:
RPM: 1206 /min
Load: 22.7 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 26.0°C
Voltage: 11.684 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:27
Freeze Frame:
RPM: 1209 /min
Load: 29.0 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 25.0°C
Voltage: 12.954 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:27
Freeze Frame:
RPM: 1209 /min
Load: 29.0 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 25.0°C
Voltage: 12.954 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:31
Freeze Frame:
RPM: 1053 /min
Load: 25.1 %
Speed: 0.0 km/h
Temperature: 32.0°C
Temperature: 25.0°C
Voltage: 13.208 V
Coding: 110D18
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 231
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:23
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x0026
Hex Value: 0x4693
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 231
Mileage: 58942 km
Time Indication: 0
Date: 2015.11.18
Time: 11:02:24
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x62A2
Hex Value: 0x0032
Hex Value: 0x0294
Hex Value: 0x00FF
Jontelito
A4 (B8 Platform) Discussion
07-19-2017 03:15 PM
Jontelito
07-19-2017 11:47 AM
