Audi A4 99 problems.
Greatings from norway.
I replaced the engine this winter, after replacing the engine i had some problems with the car since.
Turnsignal, hazard light and engine electronics.
it startet with the turnsignal and hazard light work periodical. When i start the car the turnsignal work. As i ride and the engine heats up they blink 2-3 times and die. Pullingover and restart and still maybe 2-3 blinks and die again. Hazardlight don't work at all. Replaiced the relay and the same problem. Road with this a couple of weeks and then the car suddently stops in the parkinglot. Try to restart it without turning the ignition of and just cranks and don't ignite. Turning the ignition off and try again and it starts. Didn't think more about it until ymlast week when my wife road the car and it shut down while riding. Check the faultcodes and found crash signal shorten to ground and crash shutdown activated? A
any advise what it could be ? It's no faultcodes on the airbag, cheked the restsiance on groundpoints in the engine bay and almost non reststance anywhere....
i wondering if the fault on my car are contected.
replaced the fuelpump relay, and wiper relay ? Any advise ?
And is there chrash sensors in the enginebay i could have broke when i repaced the engine ?
Autoscan, if that helps
VCDS Version: Release 14.10.0
Data version: 20141022
Wednesday,03,May,2017,15:19:15:58836
Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2001)
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Mileage: 278260km-172902miles
Address 01: Engine Labels: 06B-907-557-AHL.clb
Part No: 3B0 907 557 N
Component: 1.6l R4/2V SIMOS HS D03
Coding: 04001
Shop #: WSC 06325
VCID: 346D772504DEBB81BB3-4B18
2 Faults Found:
18017 - Crash Shut-Down Activated
P1609 - 29-00 -
01656 - Crash Signal
29-10 - Short to Ground - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl
Part No: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Shop #: BB 24548
VCID: 5EB9F58DDAD241D13D7-515A
No fault code found.
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 N
Component: A4 KLIMAAUTOMAT D57
Coding: 00040
Shop #: WSC 06325
VCID: 2B5F6C59D9E0E479EA9-2592
1 Fault Found:
01272 - Positioning Motor for Central Flap (V70)
41-10 - Blocked or No Voltage - Intermittent
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 F
Component: Airbag Front+Kopf 1001
Coding: 00306
Shop #: WSC 06325
VCID: 3973461123BC46E9685-5196
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 900 K
Component: KOMBI+WEGFAHRS. M73 D13
Coding: 00182
Shop #: WSC 00000
VCID: 2B5F6C59D9E0E479EA9-4B18
Subsystem 1 - Part No: Ident
Component: Nr. Wegfahrs.:AUZ5Z0XD104047
Ident.-Nr. Wegfahrs.:AUZ5Z0XD104047
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 G
Component: ZV-Pumpe, DWA, Funk D11
Coding: 13130
Shop #: WSC 00000
VCID: 3973461123BC46E9685-4F02
End-------------------------(Elapsed Time: 04:24)--------------------------
Coding: 04001
Shop #: WSC 06325
2 Faults Found:
P1609 - 29-00 -
Readiness: N/A
Shop #: BB 24548
Coding: 00040
Shop #: WSC 06325
1 Fault Found:
Coding: 00306
Shop #: WSC 06325
Coding: 00182
Shop #: WSC 00000
Coding: 13130
Shop #: WSC 00000
blueskies1974
A6 (C7 Platform) Discussion
02-01-2020 05:59 PM
joseph.mardini
A4 (B8 Platform) Discussion
08-20-2018 07:38 AM
kristkr
09-18-2005 11:08 AM
Carfanatic(Darren)
06-10-2002 10:47 PM
