Audi s5 rear brakes change without a battery charger.
so like a dumbass I tried to do the replacement without a battery charger thinking since the car is turned off.... well everything went fine. Closed the brakes and did a function test and it worked. Everything cycled so when I tried to start the car, I got the brake malfunction light then bunch of **** happened. Car completely died. All of the electronics like abs, seat control steering ect came up as malfunction. I figured it all the fault codes were due to battery being dead which I was correct. I hooked up a portable jump kit and everything came back on and fault codes all went away except low power supply. Car still won’t start with the portable jump kit attached but I think it’s cause the jumper is for small sedans. I don’t think it has much cranking amp but enough to jump my Honda Civic! Anyways, I don’t know what’s going on. Should I jump from my civic? Since it would be more cranking amps?
saberry0530
01-31-2019 12:29 PM
jeguzik
06-20-2012 04:01 AM
jeguzik
06-18-2012 05:35 AM
KOpork
03-15-2005 06:41 AM
zon
05-21-2003 06:38 PM
