Cant' figure this one out. Can someone help?
2003 A4 1.8L 5sp. When starting the engine, the engine runs for 3 seconds and turns off. It does this on occassion. Thanks, Tony
Sunday,23,March,2008,20:36:35:19577
VAG-COM Version: Release 704.1
Address 01: Engine
Control Module Part Number: 8E0 909 518 AF
Component and/or Version: 1.8L R4/5VT G 0001
Software Coding: 0016701
Work Shop Code: WSC 65728
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 008 - Implausible Signal - Intermittent
Readiness: 0000 0000
Address 01: Engine
1 Fault Found:
The coil itself is nearly never faulty, however the wiring to the coil is a common cause.
Especially in the early A4 8E, there have been known problems with faulty wiring. As Uwe already requested, before replacing anything the 1st thing you should do is check the instrument cluster for fault codes too, since the code you posted yet may also have different causes than the reader coil.
Appreciate the extra advise and info here! Thanks.
Although the circuit is typically faulty, instead of the reader coil itself, the dealerships usually replace the coil and the circuit faults gets fixed by default.
carsluTT
10-06-2017 05:04 AM
cpbetts
02-24-2004 11:05 AM
