Code: 00785 temp sensor in instrument panel
When posting questions involving trouble codes, post the complete code(s), and the text that comes with them. Do not omit anything, and don't drop any digits, not even a leading zero! Make sure to mention which controller (Engine, ABS, etc.) had the fault code(s). VAG codes are 5 digit numbers, unlike Generic OBD-II P-Codes, which are the letter P followed by four numbers. If you have a diagnostics question relating to VAG-COM or one of the factory tools (VAG-1551, VAS-5052, etc.), feel free to post it here. If you have a diagnostics question relating to an Autozone scan, it should be posted in the AudiWorld Autozone Forum ;-) or in a forum relating to your specific vehicle or engine. Any posts that do not pertain to VAG-COM or VAG diagnostics will be locked or moved by moderators.</i>
* Open or short circuit between G56 and E87.
* G56 malfunction.
It suggests the following further actions:
* Diagnose and repair open or short circuit using wiring diagrams.
* G56 electrical tests (which appear to require a 1589 "break out box".
G56 itself appears to be part of a switch mounting plate. Replacing it would appear to require removing the radio and the "center section of the instrument panel complete (trim and supports)".
-Uwe-
