DTC001632
DTC001632
I have just been resurrecting a 2006 Audi A6 C6 3.2l fsi s-line quattro that has been stood for 3 years -
Got pretty much everything back to specification except there is 1 fault I cannot get rid of.
Anybody shed any light on this for me?
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F1 910 559 N HW: 4F1 907 559
Component: 3.2l V6 FSI 0010
Revision: --H15--- Serial number:
Coding: 010D0003190F0120
Shop #: WSC 02325 785 00200
VCID: 3668EC774105EBFF73-8062
1 Fault Found:
001632 - Intake Manifold Tuning Valve Control Circuit (Bank 1)
P0660 - 009 - Elect. Malfunction
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 20
Reset counter: 40
Mileage: 253282 km
Time Indication: 0
Date: 2005.02.01
Time: 18:01:09
Freeze Frame:
RPM: 1568 /min
Mass Air / Rev.: 147.2 mg/str
Temperature: 25.5°C
Idle
Voltage: 11.63 V
Speed: 0.0 km/h
Readiness: 0010 0001
thanks
Mark
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 20
Reset counter: 40
Mileage: 253282 km
Time Indication: 0
Date: 2005.02.01
Time: 18:01:09
Freeze Frame:
RPM: 1568 /min
Temperature: 25.5°C
Idle
Voltage: 11.63 V
Speed: 0.0 km/h
thanks
Mark
I believe that's the tuning valve on the front of the intake manifold. Front and center on the intake under the audi engine cover there should be a 2 wire connector. Using a diagram, find which pin #/ terminal they are on the ecu connector. Check continuity and resistance from the intake/solenoid connector to ecu connector, end to end. Also Ohm said solenoid on the intake. Those results should point you in the right direction as to where to continue from there.
Indeed you are correct - went to have a look at it and with the slightest of touches the 2 wires came out of the connector!!!
looks like a generic Amphenol connector - may have 1 laying around somewhere - failing that a temporary bodge may have to come into play !!!
thanks Sam
Mark
thanks Sam
Mark
Glad to hear! Yes that is a very common connector on vag cars. Or if you had a correct wire terminal tool and a extra connector with female wire ends from a different harness, just de-pin it and use the wires with sauder or butt connectors in the excisting connector. When you get it fixed, let us know if it’s problem solved.
Managed to find a replacement connector and spliced it in - all good now, the fault has disappeared !!!
However, a new fault has come about -
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Control Module Part Number: 4F1 910 732 D HW: 4E0 035 729
Component and/or Version: Interfacebox H43 5570
Software Coding: 0031002
Work Shop Code: WSC 00000 000 08192
Additional Info: 4F0910609B Bedienteil MMIC6H03 0010
Additional Info: Geraet 08192
VCID: 254A3B3BECA39067CA-8070
1 Fault Found:
00453 - Function Limitation due to Over-Temperature
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 62
Mileage: 253297 km
Time Indication: 0
Date: 2019.07.11
Time: 16:43:28
Freeze Frame:
Temperature: 155.0°C
Bearing in mind how easy the previous wires broke, I think I may have damaged another connector, any idea where this one is?
Mark
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 62
Mileage: 253297 km
Time Indication: 0
Date: 2019.07.11
Time: 16:43:28
Freeze Frame:
Mark
Good to hear. I would clear the fault and see if it comes back, maybe just a hic-up ? But either way i think thats the mmi module? dont hold me to it but i believe its located behind the mmi screen in the dash.
stroker351w
12-05-2014 04:25 AM
LMSI-G35X
04-13-2013 07:53 PM
