engine codes please help
Can someone explain the codes on my car?
I also noticed a white smoke from the exhaust. Address 01: Engine Labels: 058-907-55x-AEB2.lbl Part No: 8D0 907 557 S Component: 1,8L R4/5V MOTR AT D03 Coding: 02031 Shop #: WSC 06335 VCID: 40855ED94098E29 6 Faults Found: 16518 - Oxygen (Lambda) Sensor B1 S1 P0134 - 35-10 - No Activity - Intermittent 17972 - Throttle Actuator (J338) P1564 - 35-10 - Under-Voltage during Basic Setting - Intermittent 17978 - Engine Start Blocked by Immobilizer P1570 - 35-00 - 00561 - Mixture Adaptation 12-10 - Adaptation Limit (Mul) Exceeded - Intermittent 17916 - Idle Control Sys P1508 - 35-10 - Upper Regulation Limit Reached - Intermittent 16500 - Engine Coolant Temp. Sensor (G62) P0116 - 35-10 - Implausible Signal - Intermittent Readiness: N/A |
