VAG-COM Discussion
Fault codes
Old Jun 21, 2004 | 09:59 AM
s4bazza's Avatar
New Member
Default Fault codes
I have a 2000 s4 and have just noticed a considerable power drop.
it only happens in the lower gears, so i plugged vag com in and this is the error message it gave me
17538- Fuel Trim: Bank 2 (mult): system too lean
p1130 - 35-00 - -
Do i need a new MAF or is there something more serious wrong with the car
Thanks in advance
Cheers
Bazza
Old Jun 22, 2004 | 10:13 AM
QCRAZY's Avatar
Default Could be the MAF....
...but that usually effects both banks, as would a TBB leak.
Go out and log block 003 for the engine module. See what your airflow is at 6000-6500 RPM at WOT.
Old Jun 22, 2004 | 11:30 AM
s4bazza's Avatar
New Member
Default actual reading ??
what should the read out be.
Im running a chipped S4 which is around about 320bhp.
thanks for you help
Bazza
Old Jun 23, 2004 | 07:05 AM
QCRAZY's Avatar
Probably 260+ g/s depending on chip. You'll know if it's bad...it will be real low.
Old Jun 23, 2004 | 10:27 AM
s4bazza's Avatar
New Member
thanks
Hoodini
Jul 31, 2005 11:31 AM
rmonckton
15
Jan 20, 2005 09:26 PM
Kawika
VAG-COM Discussion
Apr 8, 2004 08:12 PM
aadler
VAG-COM Discussion
Nov 17, 2003 11:21 AM
PILL PUSHER
Oct 25, 2003 12:19 PM
