Help with airbag error, please
Hi,
I installed a slightly used TT-RS steering wheel and airbag in my 2007 RS4. I had Alex at Europrice.com re-pin the wiring harness for me. All steering wheel functions work great but the airbag light is on. Everybody else who did this swap claim no recoding was necessary. I can clear the error code but it just comes right back. Your help will be greatly appreciated! Here is the VAG-COM report: Control Module Part Number: 8E0 959 655 H HW: 8E0 959 655 H Component and/or Version: Airbag 9.41 H12 3840 Software Coding: 0432607 Work Shop Code: WSC 06335 000 00000 Additional Info: 8E0910339B BF-Gewichtsens. 002 0070 Additional Info: Geraet 00000 1 Fault Found: 01587 - Igniter 2 for Airbag; Drivers Side (N250) 002 - Lower Limit Exceeded - MIL ON Freeze Frame: Fault Status: 11100010 Fault Priority: 1 Fault Frequency: 1 Time Indication: 0 |
Never mind, it's working now :D I swapped out parts until the trouble was traced to a bad steering wheel wiring harness. It's unclear what is wrong with it as everything checked out with a multimeter. I ended up re-using my old RS4 harness, soldering on the correctly-sized female spade connectors.
Thanks for looking. |
