HELP!! Guys, here's the code that's causing problems...Vag's "Instruments" and 00576 terminal 15
That's the code:
00576 terminal 15 27-00 - Implausible signal Anyone have any clue? We're working with Dick's help at DSR. Thanks in advance. |
Terminal 15 is switched power
i.e. the power that that comes on when you turn the ignition switch to the "on" position. But Dick should know this already.
I don't know exactly what conditions would cause your cluster to decide that the it's switched power input was in an implausible state. Are there any actual symptoms of a malfunction? Any wiring mods? Aftermarket stuff tapped in? -Uwe- |
