VAG-COM Discussion
Sponsored by:
Sponsored by:
Fault codes. What could be the problem?
Old 07-22-2010, 10:59 PM
gpan79's Avatar
Default Fault codes. What could be the problem?
VAG-COM Version: Release 311.2-N
Control Module Part Number: 4B0 906 018 AA
Component and/or Version: 1.8L R4/5VT 0006
Software Coding: 04201
Work Shop Code: WSC 00000
2 Faults Found:
17743 - Engine Torque Monitor 2: Control Limit Exceeded
P1335 - 35-10 - - - Intermittent
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
Old 07-23-2010, 12:16 AM
Kristopher's Avatar
I got the exact same P1113. Cleared it two weeks ago and it came back. When the fault is logged the car hesitates at around zero vacuum. I'm debating changing the plugs first and I've tested the O2 sensor heater which seems to be within spec, but I'll likely order a universal bosch O2 in the end.
Old 10-28-2010, 11:13 PM
Kristopher's Avatar
Update: a while back I changed the B1S1 O2 and all is well.
1999Audi
02-11-2009 07:27 PM
wclepse
VAG-COM Discussion
05-19-2007 04:04 AM
BlackS4tt (Josh)
15
11-09-2005 05:39 PM
BlackS4tt (Josh)
10-18-2005 01:28 PM
CTMechE
09-01-2004 08:00 AM
Quick Reply: Fault codes. What could be the problem?
