Lean at idle and misfire on cyl 2 at idle! :(
Hi,
I've got the following code: VAG-COM Version: Release 504.1-UD Control Module Part Number: 8P0 907 115 D Component and/or Version: 2.0l R4/4V TFSI G00 0050 Software Coding: 0103001018070160 Work Shop Code: WSC 06314 1 Fault Found: 008583 - Bank 1; System too Lean at Idle P2187 - 004 - No Signal/Communication - Intermittent I've had a look at the fuel trim and they look ok. Idle around 1.3 - 2%, Partial around -3.5% I also tried to do the carb cleaner vacuum leak test and the car did not react when I sprayed it near the boost pipes etc. What I did however notice is a constant misfire on cyl 2 when at idle....VAG registers around 7 times (per minute I assume). When driving there are no misfires!?!?!?!? WTF? HELP PLEASE! Went to Audi and the main techie said he has never seen a lean at idle code Wonder why I even bothered to visit the Audi dealer!!! |
year/make/model?
and if it's still under warranty, which it looks like it should be, then I'm thinking it should be up to them to fix it
Re: year/make/model?
2005 Audi A3 2.0T 3 door :)
My lean at idle problem can be found here:
http://audifans.com/pipermail/a4/2006-January/001680.html Doesn't seem like your situation though.<ul><li><a href="http://audifans.com/pipermail/a4/2006-January/001680.html">http://audifans.com/pipermail/a4/2006-January/001680.html</a</li></ul> |
Audi is now replacing the MAF...not sure that that will aoso fix the misfire on cylinder 2 but they say it will solve all my problems. I disagree but I guess we'll see ;)
Re: misfire - link
I saw this in the newsgroups and assumed it was you. Might want to check it out. --Art
----- Original Message ----- From: Alec Newsgroups: alt.autos.audi Sent: Friday, February 17, 2006 5:57 PM Subject: Re: audi a4 misfire > hi have a audi s4 1.8t i have a problem i have tried everything from the > coil packs to the computer and cylinder no2 has no spark??? > If it is an early 1.8T (AEB) then this is probably the fault : http://www.robsaudiworld.com/ignition.htm Rgds<ul><li><a href="http://www.robsaudiworld.com/ignition.htm">http://www.robsaudiworld.com/ignition.htm</a</li></ul> |
