level control sensor help
I had the following fault:
Address 55 ------------------------------------------------------- Controller: 4B0 907 357 B Component: dynamische LWR D02 Coding: 00020 Shop #: WSC 02335 1 Fault Found: 00776 - Level Control System Sensor: Left Front (G78) 31-00 - Open or Short to Ground so thought it would be the sensor, have purchased a new sensor - was having trouble unbolting the old one off so thought i would plug the new one in and clear the codes. Then ran vag com again this has however not made any difference. Any ideas? Ian. |
Checked the wiring yet?
<ul><li><a href="http://wiki.ross-tech.com/index.php/00776">http://wiki.ross-tech.com/index.php/00776</a</li></ul>
Re: Checked the wiring yet?
yep - took the front wheel off, and tested with a multimeter the + voltage and the - voltage going to the suspension sensor. These both seem to be ok.
I purchased a new sensor from audi a week or so ago - plugged that in (still getting error codes - so I believe the last thing it could be is the output wire from the sensor to the control module. Using the measuring units on vag com I can seen the rear sensor is outputing approx 1.58/1.60 volts the front is outputing 0.02v. I cant see where the wiring goes from the front wheel sensor to the control module - I dont know where the module is located on the car. Any help anyone - thanks. |
