Is it normal for A6 2.7T
<center><img src="http://www.freewebs.com/chrishong1208/maf.JPG"></center><p>Is it normal???
My car lose power, Also, i got code misfire and EGT 18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction P1606 - 35-00 - - 17865 - Exhaust Gas Temp Sensor 2 (G236): Open or Short to Plus P1457 - 35-00 - - 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-10 - - - Intermittent 16688 - Cylinder 4: Misfire Detected P0304 - 35-10 - - - Intermittent 16689 - Cylinder 5: Misfire Detected P0305 - 35-10 - - - Intermittent --------------------------------------------------------------------------- |
thoughts inside
1. You sure you have the correct ECU in?
2. Your EGT sensor is bad - replace both of them to be safe. 3. Your misfires could come from several things - search the B5 S4 archives for suggestions. |
Here is LOG file for MAF
LOG for MAF<ul><li><a href="http://www.freewebs.com/chrishong1208/LOG.CSV">LOG FOR MAF</a></li></ul>
