Not "seeing" S4 ABS Module
Just hooked up the V-C to our '00 S4 for the first time this morning.
It detected all other modules, but no ABS?
Does this mean the ABS module is fried?
The ABS and Brake fault lights are on, but the brakes themselves are functioning fine.
Any suggestions for next steps?
Thanks
Thanks
If abs light and brake is on then your abs is disabled but your normal..
but your normal braking is fine. Just check the wiring on your module (incase someone pulled a wire) I believe the module is located in the middle of the dash by the radio on the bottom or the top of it (not 100%), If you go to the dealer all they are going to tell you is to replace the module ( they hate doing diag and just skip to the easy way out) Try to get a wiring diag and look for 30 power (battery), or (ign power)15 power to make sure power is going to that module and if it is not... then it might be something stupid like a relay or fuse or to much resistance in a wire (that could have been repaired and has corrosion or what ever) Try to do the easy stuff first. gl
S4 Slowpoke
10-10-2006 06:10 PM
