VAG-COM Discussion
Sponsored by:
Sponsored by:
Not an Audi but.... this is an error on my father's Bentley Flying Spur ... what can this be?
Old 10-06-2008, 02:10 AM
New Member
dihanie's Avatar
Default Not an Audi but.... this is an error on my father's Bentley Flying Spur ... what can this be?
Friday,26,September,2008,21:07:12:59303
VAG-COM Version: Release 704.1
Address 01: Engine
Control Module Part Number: 07C 906 018 BP
Component and/or Version: BY-6.0L-TT G ª6767
Software Coding: 0001175
Work Shop Code: WSC 01065
1 Fault Found:
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 54623 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 67.0°C
Temperature: 63.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 11.811 V
Readiness: 0110 1101
Old 10-06-2008, 12:28 PM
Audiworld Premium Sponsor
Santos@Ross-Tech's Avatar
Did you check engine II for codes?
Santos@Ross-Tech.com
Old 10-06-2008, 11:54 PM
New Member
dihanie's Avatar
Default Re: Did you check engine II for codes?
Tuesday,07,October,2008,09:41:08:59303
Data version: 20070422
Chassis Type: 3W - Bentley GT/Spur
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 1C 23 27 28 29
34 36 37 38 39 46 47 53 57 65 66 68 69 6C 71 75 76 77
VIN: SCBBE53W178040741 Mileage: 55950km/34765miles
Address 01: Engine Labels: None
Part No SW: 07C 906 018 BP HW: 07C 906 018 EC
Component: BY-6.0L-TT G ?6767
Coding: 0001175
Shop #: WSC 01065
3 Faults Found:
049508 - No Communications with HVAC Control Module (J301)
PC164 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 155
Mileage: 55751 km
Time Indication: 0
Freeze Frame:
RPM: 1228 /min
Load: 18.0 %
Speed: 27.0 km/h
Temperature: 92.0°C
Temperature: 36.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.462 V
049412 - No Communication with Cruise Control Module
PC104 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 45
Mileage: 55751 km
Time Indication: 0
Freeze Frame:
RPM: 1719 /min
Load: 30.2 %
Speed: 72.0 km/h
Temperature: 92.0°C
Temperature: 17.0°C
Voltage: 13.462 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 55950 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 57.0°C
Temperature: 61.0°C
Absolute Pres.: 980.0 mbar
Voltage: 11.684 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: None
Part No SW: 09E 927 760 T HW: GS1 9.1 1.4
Component: AG6 09E 6.0L W12TT 2808
Coding: 0000111
Shop #: WSC 00000
No fault code found.
Address 03: ABS Brakes Labels: 3W0-614-517.LBL
Part No: 3W0 614 517 F
Component: ESP 5.7 4WD H01 0047
Coding: 0006878
Shop #: WSC 07361
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.LBL
Part No SW: 3D0 909 137 B HW: 5WK 484 95
Component: 5C Kessy 6700
Coding: 0422125
Shop #: WSC 01065
Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00457 - Control Module for Network (J519)
004 - No Signal/Communication
Address 06: Seat Mem. Pass Labels: 3D0-959-759.LBL
Part No: 3D0 959 759 CA
Component: Sitzmemory D1 BF 1720
Coding: 0000003
Shop #: WSC 01065
6 Faults Found:
004 - No Signal/Communication - Intermittent
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
00462 - Control Module for Seat Memory; Rear (J522)
01336 - Data Bus for Comfort System
014 - Defective - Intermittent
Address 07: Control Head Labels: None
Part No: 3W0 035 007 K
Component: ZAB COCKPIT 2142
Coding: 0500335
Shop #: WSC 07361
15 Faults Found:
01320 - Control Module for Climatronic (J255)
01312 - Powertrain Data Bus
013 - Check DTC Memory - Intermittent
01325 - Control Module for Tire Pressure Monitoring (J502)
01330 - Central Control Module for Central Convenience (J393)
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J398)
01308 - Control Module for Roof Electronics (J528)
00466 - Control Module for Steering Column Electronics (J527)
00565 - Rear A/C Control Head (Climatronic) (E265)
Address 08: Auto HVAC Labels: None
Part No: 3W5 907 040 F
Component: Climatronic BY611 2026
Coding: 0000111
Shop #: WSC 01065
4 Faults Found:
00908 - Control Module for Wiper Motor
Address 09: Cent. Elect. Labels: 3D0-937-049.LBL
Part No: 3D0 937 049 H
Component: STG.Bordnetz 5101
Coding: 0000107
Shop #: WSC 01065
4 Faults Found:
00907 - Intervention load Management
000 - -
Address 11: Engine II Labels: None
Coding: 0001175
Shop #: WSC 01065
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 254
Mileage: 53336 km
Time Indication: 0
Freeze Frame:
RPM: 1229 /min
Load: 17.6 %
Speed: 27.0 km/h
Temperature: 92.0°C
Temperature: 33.0°C
Voltage: 13.335 V
009270 - SAE - Sec. Air Inj. Sys. Air Flow/Pressure Sens Bank 2 Circuit: Range/Perf.
P2436 - 008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 54171 km
Time Indication: 0
Freeze Frame:
RPM: 780 /min
Load: 32.1 %
Speed: 0.0 km/h
Temperature: 32.0°C
Temperature: 27.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.462 V
Address 15: Airbags Labels: None
Part No SW: 3W8 909 601 HW: 3W8 909 601
Component: 09 Airbag 9.41 H13 0040
Coding: 0012345
Shop #: WSC 01065
Address 16: Steering wheel Labels: 3D0-953-549.LBL
Part No: 3D0 953 549 E
Component: Lenks?ulenmodul 3401
Coding: 0000212
Shop #: WSC 01065
4 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
Address 17: Instruments Labels: None
Part No: 3W5 920 840 F
Component: KOMBIINSTRUMENT RB8 0610
Coding: 0021103
Shop #: WSC 01065
7 Faults Found:
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit - Intermittent
012 - Electrical Fault in Circuit - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901.LBL
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
Shop #: WSC 01065
9 Faults Found:
Address 28: HVAC, Rear Labels: None
Part No: 3W5 907 049 A
Component: Rear HVAC Head Unit 0004
3 Faults Found:
Address 34: Level Control Labels: None
Part No: 3W5 907 553
Component: LUFTFDR.-CDC- 3C3V0 7032
Coding: 0005551
Shop #: WSC 07191
1 Fault Found:
Address 36: Seat Mem. Drvr Labels: 3D0-959-760.LBL
Part No: 3D0 959 760 CA
Component: Sitzmemory D1 F 1720
Coding: 0000004
Shop #: WSC 01065
9 Faults Found:
Address 37: Navigation Labels: None
Part No: 3W0 919 887 D
Component: NAVIGATION 2085
Coding: 0400000
Shop #: WSC 01065
Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 E
Component: Dachmodul 0707
Coding: 0000013
Shop #: WSC 01065
6 Faults Found:
00510 - Motor for Wind Deflector (V252)
000 - - - Intermittent
00220 - Connection to Sunroof
00405 - Sunroof Shade Motor (V260)
Address 46: Central Conv. Labels: 3D0-959-933.LBL
Part No: 3D0 959 933 F
Component: 4Y HSG 0101
Coding: 0000040
Shop #: WSC 01065
Part No: 3W5 959 701 B
Component: Tuersteuergeraet FS 1001
Part No: 3W5 959 702 B
Component: Tuersteuergeraet BF 1001
Part No: 3W5 959 703 A
Component: Tuersteuergeraet HL 1001
Part No: 3W5 959 704 A
Component: Tuersteuergeraet HR 1001
Part No: 3W0 909 610 F
Component: 11 HDSG 1809
Part No: 7L0 907 719 A
Component: Neigungssensor 0020
11 Faults Found:
Address 47: Sound System Labels: None
Part No: 3W5 035 456 A
Component: 12K-AUDIOVERST 0006
Address 53: Parking Brake Labels: None
Part No SW: 3W0 907 801 D HW: 3W0 907 801 D
Component: EPB BC6HX24 HC6 X240
Coding: 0022413
Shop #: WSC 01065
Address 57: TV Tuner Labels: 3D0-919-146.LBL
Part No: 3D0 919 146
Component: TV Tuner H07 1205
Coding: 0000010
Shop #: WSC 01065
Address 65: Tire Pressure Labels: None
Part No: 3W7 907 273
Component: Reifendruckueberw. 0003
Coding: 0070311
Shop #: WSC 01065
3 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
Address 66: Seat, Rear PS Labels: 3D0-959-860.LBL
Part No: 3D0 959 860 C
Component: Sitzmemory D1 H 1724
Coding: 0000001
Shop #: WSC 00000
8 Faults Found:
Address 68: Wiper Electr. Labels: None
Part No: 3W5 955 023 B
Component: Wischermodul ?8326
8 Faults Found:
00003 - Control Module
014 - Defective
00459 - Control Module for Display and Input; Front (J523)
Address 71: Battery Charger Labels: 3D0-915-181.LBL
Part No: 3D0 915 181 D
Component: Batteriemanagement 2800
Address 77: Telephone Labels: None
Part No SW: 3W0 035 385 AD HW: 3W0 035 385 AD
Component: rSAP ECU 0054
Coding: 0000272
Shop #: WSC 00000
1 Fault Found:
End --------------------------------------------------------------------------------------------------
Here are all the errors...
I've also notice that i can't erase errors, my vag-com version doesn't go with Bentley?
JNormS4
06-04-2013 05:19 PM
GaBoYnFla
TT (Mk2) Discussion
07-09-2011 06:59 PM
rmarin2
VAG-COM Discussion
02-21-2008 03:35 AM
AudiRX
VAG-COM Discussion
04-27-2007 01:31 PM
Jack Wang
VAG-COM Discussion
02-19-2007 04:16 AM
Quick Reply: Not an Audi but.... this is an error on my father's Bentley Flying Spur ... what can this be?
