VAG-COM Discussion
Problems coding Control Module 76 (Parking Aid)
Old Jan 30, 2008 | 07:25 AM
ELEVENS's Avatar
Default Problems coding Control Module 76 (Parking Aid)
2007 RS4 with VAG-COM v. 704.1
Trying to turn off the Reverse gear confirmation beep in Control Module 76. My car's coding is 0000304, seems like it should be 0000504. When I try to change the coding, the change won't stick.
Also tried to change adaptation 10 channel 05 to "0" but that won't stick either -it's stuck at 135 (if memory serves).
Any ideas? TIA.
Old Jan 30, 2008 | 07:38 AM
Andy@Ross-Tech's Avatar
Banned
Please post a complete AutoScan.
Old Jan 30, 2008 | 01:33 PM
ELEVENS's Avatar
Default Does the presence of a fault prevent coding changes?
Because there's a bad sensor connection thanks to the paint shop:
Address 76: Park Assist Labels: 8E0-919-283-8EC.LBL
Part No SW: 8E0 919 283 D HW: 8E0 919 283 D
Component: Parkhilfe 4-Kan H06 0010
Coding: 0000304
Shop #: WSC 06335
1 Fault Found:
01545 - Sensor for Parking Aid; Rear Left (G203)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 12
Time Indication: 0
Old Jan 30, 2008 | 01:36 PM
Banned
Yes, it could cause problems. Best to resolve that issue first.
Old Jan 30, 2008 | 01:40 PM
ELEVENS's Avatar
Andy, you win the "fastest answer award". Thanks, I'll get on the repair tonight.
Old Jan 30, 2008 | 05:45 PM
ELEVENS's Avatar
Default OK fixed the sensor, no more faults, but the coding is really whacko
Control Module 76 will not take the correct 0000504, but will take 0000304 and 0000204.
Also, adaptation channel 05 should be "1" for Reverse beep confirmation, and "0" for No Confirmation. However, my car is 135. Through trial and error, I found that 136 turns off the Reverse beep.
What's up with my car? I posted over in the B7RS4 forum asking for another RS4's coding, but no replies.
TrevorAustin
Jan 12, 2019 05:24 AM
vtraudt
Audi allroad
Mar 9, 2015 07:56 PM
Pchelka01
Audi allroad
18
Aug 19, 2012 11:06 PM
Paramount Motors
Dec 8, 2011 06:08 PM
xtreetoes
Audi allroad
Mar 13, 2007 06:57 AM
