Recoding trouble on 2007 RS4...
Just took delivery of my 2007 RS4 and want to make the seatbelt chime less obnoxious.
I have done this on another RS4 a few weeks ago with no problems. The default code on the car I did previously was 0023261. I changed the code to 0023258 and the chime was eliminated.
Now on my new car I open the "Instruments" section and the default does not match what I saw previously. It is 0023268 on mine. I try to change the value to 0023258 and the code doesn't change. Hitting "Do-it" only brings my back to the default code.
Any suggestions?
Thanks!
Any suggestions?
Thanks!
Ran the Auto-Scan...
The results are in!
No faults that I see, so what could be the problem? I was able to change the window up/dn with the remote successfully.
VAG-COM Version: Release 704.1
Data version: 20070422
Monday,28,May,2007,19:17:14:03091
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WUARU78E17N90**** Mileage: 300km/186miles
Address 01: Engine Labels: 079-910-560-BNS1.LBL
Part No SW: 8E1 910 560 F HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0020
Coding: 01040009180F0160
Shop #: WSC 08216
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-910-517.LBL
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Coding: 0004533
Shop #: WSC 06335
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 3233
Coding: 00000
Shop #: WSC 00000
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.LBL
Part No: 8E0 907 279 N
Component: int. Lastmodul USA 0907
Coding: 01023
Shop #: WSC 06335
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.LBL
Part No SW: 8E0 035 593 H HW:
Component: SDAR SIRIUS 0080
Address 11: Engine II Labels: None
Shop #: WSC 08216
Address 15: Airbags Labels: 8E0-959-655-94.LBL
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H13 4240
Coding: 0432607
Shop #: WSC 06335
Part No: 8E0 910 339 D
Component: BF-Gewichtsens. H03 0080
Address 16: Steering wheel Labels: 8E0-953-549-T.LBL
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0301
Coding: 04441
Shop #: WSC 06335
Address 17: Instruments Labels: 8E0-920-9xx-8EC.LBL
Part No SW: 8E0 920 983 F HW: 8E0 920 983 F
Component: KOMBI+WFS 4 H10 0100
Coding: 0023268
Shop #: WSC 08216
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.LBL
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 00000
Address 37: Navigation Labels: 8E0-035-192-RNSE.LBL
Part No SW: 8E0 035 192 P HW: 8E0 035 192 P
Component: RNS-E US3 H73 0150
Coding: 0309637
Shop #: WSC 02197
Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
Part No: 8E0 959 433 CG
Component: Komfortgerát T7B 4135
Coding: 11884
Shop #: WSC 06335
Part No: 8E1959801G
Component: Tõrsteuer.FS BRM 0706
Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
Address 55: Xenon Range Labels: 4F0-910-357.LBL
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000019
Shop #: WSC 06335
Part No: 8E0 941 329 A
Component: AFS-Modul links H04 0020
Component: AFS-Modul rechtsH04 0020
Address 56: Radio Labels: 8E0-035-192-RNSE.LBL
Coding: 0309637
Shop #: WSC 02197
Address 65: Tire Pressure Labels: 8E0-907-273.LBL
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0062523
Shop #: WSC 02195
Address 76: Park Assist Labels: 8E0-919-283-8EC.LBL
Part No SW: 8E0 919 283 D HW: 8E0 919 283 D
Component: Parkhilfe 4-Kan H06 0010
Coding: 0000304
Shop #: WSC 06335
Address 77: Telephone Labels: 8P0-862-335.LBL
Part No SW: 8P0 862 335 J HW: 8P0 862 335 J
Component: FSE_255x BT H26 0290
Coding: 0011877
Shop #: WSC 06335
End --------------------------------------------------------------------------------------------------
69 75 76 77
Shop #: WSC 08216
Coding: 0004533
Shop #: WSC 06335
Coding: 00000
Shop #: WSC 00000
Coding: 01023
Shop #: WSC 06335
Shop #: WSC 08216
Coding: 0432607
Shop #: WSC 06335
Coding: 04441
Shop #: WSC 06335
Coding: 0023268
Shop #: WSC 08216
Coding: 00002
Shop #: WSC 00000
Coding: 0309637
Shop #: WSC 02197
Coding: 11884
Shop #: WSC 06335
Part No: 8E1959801G
Part No: 8E1959802G
Part No: 8E0959801E
Part No: 8E0959802E
Coding: 0000019
Shop #: WSC 06335
Coding: 0309637
Shop #: WSC 02197
Coding: 0062523
Shop #: WSC 02195
Coding: 0000304
Shop #: WSC 06335
Coding: 0011877
Shop #: WSC 06335
Thanks, that really helped. The scan itself shows more data like part numbers, software versions...
...and other details, which are in some cases important.
You are trying to recode from NAR NEW to NAR OLD, it's possible that this option has been taken out of the latest clusters, sadly none of the documentation we have access to helps. Have you tried setting it to 0 for no seatbelt warning at all?
In this particular case the last digit of the coding is the only part which doesn't directly match but we figured that difference too. It's the setting for the Washer Fluid Warning!
According to the documentation we have access to this change should be valid for cluster software versions 0200 and above, but yours is obviously 0100 (as you can see in the component id). Nothing t worry about since yours is a US model though, and they are often a little different...
Our WIKI has been updated and should cover the new details too.<ul><li><a href="http://wiki.ross-tech.com/index.php/Audi_A4_%288E%29_Instrument_Cluster_%288EC/8ED/8HE%29">http://wiki.ross-tech.com/index.php/Audi_A4_%288E%29_Instrument_Cluster_%288EC/8ED/8HE%29</a</li></ul>
I think I am figuring this out now. So you think I should try...
to recode from 0023268 to 0023208 (which should eliminate the seatbelt chime all together?)
I will give it a shot this evening.
Thank you.
Thank you.
Sellshort
VAG-COM Discussion
03-09-2009 05:09 PM
Evil Buddha
RS4 (B7 Platform) Discussion
05-03-2008 06:39 PM
AudiRS4ever
14
01-29-2008 12:55 PM
RSfizzy
04-19-2006 02:10 PM
