Request for help - 2007 Q7 multiple issues
Hi,
I am hoping someone here can help me with a problem I has been wrestling with for a few months on my 2007 Q7 3.0 TDi. Last year we started to suffer power considerable loss and surging on idle. When I ran VCDS diagnostics it presented issues with the throttle bodies. I removed the bodies and the manifolds and cleaned a lot of build up out of it (they are now like new). The swirl flaps were still working OK so I didn't replace them. On putting it all back together it became obvious I also needed to replace the left side actuator (which I did). However I am still getting the following issues. I have cleared the errors several times, the throttle circuit failure clears but them comes back within 5 minutes. All others are persistent. I don't know if the issues are related or if I am just lucky and have a cluster of issues. Any help would be greatly appreciated. Thanks, -Dean. _______________________________ Address 01: Engine Labels: Redir Fail! Part No SW: 4L0 910 401 M HW: 4L0 907 401 Component: 3.0L V6TDI G001AG 0030 Revision: --H03--- Serial number: Coding: 0011779 Shop #: WSC 31414 790 00001 VCID: 2C57E23B8FFEEC7E18B-8079 1 Fault Found: 012867 - Control Circuit for Throttle Body Module P3243 - 004 - Electrical Malfunction Freeze Frame: Fault Status: 01100100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 238075 km Time Indication: 0 Date: 2016.01.10 Time: 17:41:42 Freeze Frame: RPM: 777 /min Torque: 85.8 Nm Voltage: 13.98 V Duty Cycle: 40.6 % Duty Cycle: 0.4 % Readiness: 0 0 1 1 1 ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 ELV H31 0220 Revision: 31050601 Serial number: 10601100527710 Coding: 0000147 Shop #: WSC 31414 790 00001 VCID: E3C5C90722A0E306691-80B6 Subsystem 1 - Part No: 4F0 910 131 A Component: FBSAUDIC6 EZS H45 0080 Subsystem 2 - Part No: 4F0 910 220 Component: FBSAUDIC6 IDG H01 0040 1 Fault Found: 16347 - Control Module - EEPROM Error 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 1 Fault Frequency: 1 Reset counter: 144 Time Indication: 0 ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4L0 910 181 HW: 4L0 915 181 Component: J0644 BEM H12 0530 Revision: -------- Serial number: 00000000046932 Shop #: WSC 23050 822 88145 VCID: E4C7CA1B27AEE43E90B-80B1 Subsystem 1 - Part No: 4F0 915 105 D Component: von VA0 2609160772 Coding: 344630393135313035442056413032363039313630373732 Shop #: WSC 31414 790 00001 1 Fault Found: 03041 - Energy Management Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 12 Reset counter: 255 Mileage: 236442 km Time Indication: 0 Date: 2015.11.04 |
