Some codes just popped up....
Address 01: Engine Labels: None
Part No SW: 8E0 910 560 G HW: 8E0 907 560
Component: 4.2L V8/5V G 0010
Coding: 0007711
Shop #: WSC 12593
1 Fault Found:
16485 - Mass Air Flow Sensor (G70): Implausible Signal
P0101 - 004 - No Signal/Communication - MIL ON
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Part No: 8E0 614 517 Q
Component: ABS/ESP allrad 4533
Coding: 04595
Shop #: WSC 12345
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-00 - -
The ESP light is on constantly and the CEL light is on also. These both popped up at the same time yesterday which is a coincidence or they are related. I found someone here on the forums that had the exact same codes pop up like I did.
Coding: 0007711
Shop #: WSC 12593
1 Fault Found:
Coding: 04595
Shop #: WSC 12345
1 Fault Found:
P1857 - 35-00 - -
This sounds like a bad MAF, but I have not had this situation personally, just recall reading a post
about a bad MAF causing the ESP/ABS issues but that was with a 2.7t and not a 4.2L. Your situation could be different. Are you in limp mode/down on power? On the 2.7t, if you unplug the MAF it will go into a speed/density mode. Hope this gives you some ideas.
if you clear the codes, how quickly does it come back? maybe your system
sneezed or something? still, if it was intermittent you might be okay, but this sounds like your MAF might be going. what air filter do you have? cleaned it lately? you sure it's plugged in all the way?
Imola Ghost
01-23-2008 08:31 PM
MY01_2.7T
03-08-2007 07:00 AM
