Status: Cannot be reached 1100 (cant find any solution) - AudiWorld Forums
Go Back  AudiWorld Forums > Technical Discussion > Electronics > VAG-COM Discussion
Reload this Page > Status: Cannot be reached 1100 (cant find any solution)
VAG-COM Discussion
Sponsored by:
Sponsored by:
Old 11-14-2017, 06:43 AM
Default Status: Cannot be reached 1100 (cant find any solution)
Hello!
I wanna set a Parking Illustration on my audi a4 2013 mmi 3g.. i have only rear sensors so i dont have park ilustrator (ON) on default .
On YouTube i fallow this steps seen below on this video, but on Park/Steer Assist i get ( Status: Cannot be reached 1100 )
Any solution?
Wednesday,01,November,2017,14:49:25:54500
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
Ross-Tech: Home
VIN: WAUXXXXXXXXXXX License Plate:
Mileage: 148400km-92211mi Repair Order:--------------------------------------------------------------------------------
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 42 44 46 52 53 56 5F 62
69 72VIN: WAUXXXXXXXXX Mileage: 148400km-92211miles01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CJCA) Labels:. 03L-906-018-CGL.clb
Part No SW: 03L 906 018 HT HW: 03L 906 018 JL
Component: R4 2.0l TDI H25 9978
Revision: 45H25---
Coding: 0A034012243401080000
Shop #: WSC 61206 001 1048576
ASAM Dataset: EV_ECM20TDI01013L906018HT 003009
ROD: N/A
VCID: 030402A88AC1FC5E97-8056No ASAM data for: "EV_ECM20TDI01013L906018HT" (AU48)
No fault code found.
Readiness: 0 0 0 0 0-------------------------------------------------------------------------------
Address 02: Auto Trans (J217) Labels:. 0AW-927-156.clb
Part No SW: 8K9 927 155 A HW: 0AW 927 156 K
Component: 0AW 20TDI RdW H05 0001
Revision: --H05--- Serial number: 0000000783
Coding: 000001
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMLV381 A02432
ROD: N/A
VCID: 3A7ABF4CBD8B7D9684-806ENo ASAM data for: "EV_TCMLV381" (AU48)
2 Faults Found:
2264 - ROD - Unknown Error Code
- 00 [032]
Intermittent - Not Confirmed - Tested Since Memory Clear7066 - ROD - Unknown Error Code
- 00 [032]
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CH HW: 8K0 907 379 CH
Component: ESP8 front H09 0100
Revision: -------- Serial number: --------------
Coding: 179D4C
VCID: 010808A098DDEE4E85-8054No fault code found.-------------------------------------------------------------------------------
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 GD HW: 8K0 907 064 FD
Component: BCM2 2.0 H12 0633
Revision: 00002001
Coding: 01A14040000000000000
VCID: 78FE6544CB07AF86B2-802C Subsystem 1 - Part No SW: 8K0 959 754 D HW: 8K0 959 754 D
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0816000076256002 No fault code found.-------------------------------------------------------------------------------
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8K1 820 043 AF HW: 8K1 820 043 AF
Component: KLIMA 1 ZONE H02 0123
Revision: A0000000 Serial number: 01140120130937
Coding: 342002E000
VCID: 6CD649148F5F132646-8038No fault code found.-------------------------------------------------------------------------------
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 DG HW: 8K0 907 063 DG
Component: BCM1 1.0 H16 0103
Revision: 07016001 Serial number: 00000536696002
Coding: 260000108034AFC00081400000001D0D001C63082609020100 0004004401020100000020000000
VCID: 77FC6678C619A0FEBB-8022 Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 100113 H07 0080
Serial number: SWF13010106287
Coding: 00FD11 Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 20855812
Coding: 02005D Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000001912125118 Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: 69488466000000000001No fault code found.-------------------------------------------------------------------------------
Address 0E: Media Player 1 (R41) Labels: Redir Fail!
Part No SW: 8X0 035 110 C HW: 8X0 035 110
Component: CDC-MP3-Pana H41 0490
Revision: 00000008
VCID: 2D50841074C5DA2E11-8078No fault code found.-------------------------------------------------------------------------------
Address 10: Park/Steer Assist
Cannot be reached-------------------------------------------------------------------------------
Address 15: Airbags (J234) Labels:. 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H45 0610
Serial number: 003KFD97H4GI
Coding: 30514435363030303030554A304C384B3053
Shop #: WSC 14550 002 1048576
ASAM Dataset: EV_AirbaCEUVWAUDI010 003010
ROD: N/A
VCID: 489ED584F3671F0602-801C Subsystem 1 - Serial number: 6334MSME77226B14D Subsystem 2 - Serial number: 6344MSME761169026 Subsystem 3 - Serial number: 6352QSME7A282272H Subsystem 4 - Serial number: 6362QSME5D283F78$ Subsystem 5 - Serial number: 63732SME5B241264Y Subsystem 6 - Serial number: 63832SME5D244F48CNo ASAM data for: "EV_AirbaCEUVWAUDI010" (AU48)
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20130111000807
Coding: 000016
VCID: 4FACFE981E09C83E43-801A Component: E221 - MFL H03 0004No fault code found.-------------------------------------------------------------------------------
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8K0 920 931 J HW: 8K0 920 931 J
Component: KOMBIINSTR. H35 0556
Revision: 00200000 Serial number: UVP64071E
Coding: 1386080003010008030000
VCID: 3560AC709C9592EE69-8060No fault code found.-------------------------------------------------------------------------------
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0055
Revision: 1Y060027 Serial number: 2741Y13107803A
Coding: 80CF07FF00
VCID: 4A9AEF8CE56BED1614-801E Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 4903408801 2 Faults Found:
03705 - Voltage Regulator
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 94
Mileage: 137114 km
Time Indication: 0
Date: 2016.09.26
Time: 13:25:36 Freeze Frame:
Bin. Bits: 10111
Voltage: 13.00 V
Count: 6
Bin. Bits: 1000001327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 92
Mileage: 148359 km
Time Indication: 0
Date: 2017.11.01
Time: 08:48:21 Freeze Frame:
Bin. Bits: 11111
Voltage: 14.60 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8T0 959 793 Q HW: 8T0 959 793 F
Component: TSG FA H09 0304
Coding: 011002204000410001
VCID: 57BC06F826D980FE9B-8002No fault code found.-------------------------------------------------------------------------------
Address 44: Steering Assist (J500) Labels:. 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0028098311
Coding: 100000000001
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_RCESPAU48X 008014
ROD: N/A
VCID: 346691749FEF8BE65E-8060No ASAM data for: "EV_RCESPAU48X" (AU48)
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0300027295
Coding: 0100062000B90000812001368000000F
VCID: 78FE6544CB07AF86B2-802C1 Fault Found:
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 8
Reset counter: 129
Mileage: 145558 km
Time Indication: 0
Date: 2017.09.18
Time: 11:36:49
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8T0 959 792 Q HW: 8T0 959 792 H
Component: TSG BF H08 0304
VCID: 56A20BFC21D3B9F680-8002No fault code found.-------------------------------------------------------------------------------
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 00000001241207
ASAM Dataset: EV_AprkiBrake 001027
ROD: N/A
VCID: 387EA54483876F8672-806CNo ASAM data for: "EV_AprkiBrake" (AU48)
3 Faults Found:
334080 - ROD - Unknown Error Code
- 00 [000]
Intermittent - Not Confirmed - Tested Since Memory Clear331264 - ROD - Unknown Error Code
- 00 [000]
Intermittent - Not Confirmed - Tested Since Memory Clear331520 - ROD - Unknown Error Code
- 00 [000]
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G1 035 053 F HW: 4G1 035 053
Component: Radio U Basic H41 0122
Revision: AB001007 Serial number: 226AP0D7703314
Coding: 010003020100000001
VCID: 224A672C3D1B1556BC-8076No fault code found.-------------------------------------------------------------------------------
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 8R1 035 652 B HW: 8R1 035 652
Component: B-BN-EU H62 0176
Revision: -------- Serial number: 148A20D7599048
Coding: 010100000006A1FD05806B4E000000030000
VCID: 326A976C6DFB85D64C-8066 Subsystem 1 - Part No: 4G0 919 884 L
Component: EUR 2013 1503 Subsystem 2 - Part No SW: 8T0 919 604 A HW: 8T0 919 604 A
Component: DU6 Basic H43 0098
Serial number: 9465A+0D2607895 Subsystem 3 - Part No SW: 8T0 919 611 HW: 8T0 919 611
Component: E0380 Bedient H01 0100
Serial number: 00000001372155 1 Fault Found:
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 92
Mileage: 148359 km
Time Indication: 0
Date: 2017.11.01
Time: 09:34:14 Freeze Frame:
Bin. Bits: 00000000 00000000
Bin. Bits: 00000000 10000000
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H07 0304
Coding: 010002204000210001
VCID: 59B800C050CD968EAD-800CNo fault code found.-------------------------------------------------------------------------------
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 E HW: 8K0 907 383 E
Component: Anhaenger H09 0100
Revision: 1A001001 Serial number: 00000191056432
Coding: 010D000000000000
Shop #: WSC 25381 000 00000
VCID: 3662AB7C819399F660-8062No fault code found.-------------------------------------------------------------------------------
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H07 0304
VCID: 59B800C050CD968EAD-800CNo fault code found.End-------------------------(Elapsed Time: 02:56)--------------------------
Klemen Nemivsek is offline
