VAG-COM Discussion
Sponsored by:
Sponsored by:
TT MK1 Cluster Swap
Old 08-28-2017, 01:38 PM
carseomighty's Avatar
Default TT MK1 Cluster Swap
Hi,
I have been hunting forums for days now trying to figure out what to do, hopefully someone can point me in the right direction.
I have an 02 TT 225 Quattro. The Instrument cluster is toast but I am able to connect to it with VCDS and get status. I have the SKC for the cluster as well.
Bought a newer used cluster on ebay from a 02 TT 3.2 V6. The part number is 8N1920980E my old cluster is 8N1920980 . I have the SKC for the new cluster as well.
My problem is trying to adapt the pin I get a SYSTEM NOT OK.
Trying also through a bench harness I cant get block 50 as I imagine it passes from the ECU.
I figure I can just swap eeproms but I'm not sure which chip is the eeprom. Trying to get a dump from vag vommander causes both clusters to reboot.
From what I can tell it should be a 64K bin file but just doing a solder swap would work better for me.
TLDNR:
Can anyone tell me where the eeprom is on the cluster??
Thanks,
C.
Old 08-28-2017, 05:24 PM
well it looks like there isn't an external eeprom. The microcontroller MC912DG128 in the cluster has 128k of flash. not sure what I need to get a dump from that or if I just need some other package to swap pins in the new cluster.
messerschmiTT
01-28-2007 10:42 AM
CheeseHead Cubs Fan
20
09-01-2005 10:22 PM
talx
02-07-2005 06:53 AM
SecuriTT
12-04-2001 01:36 PM
Quick Reply: TT MK1 Cluster Swap
