Vag read out ; can anyoneoffer help
When i start the car the Radio comes on for 30s, i can not get it to switch over to any other function like nav or car. After 30 sec pass all the lights on the MMI flash and then the screen goes dark and no buttons work no sound from radio. I did the three button reset but didnt change anything. I will try to reset the faults with Vag and see if this helps. I am also gonna pull the fuse to see if it resets anything. Any one else have an idea?
VCDS Version: Release 10.6.4 Data version: 20110418 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4F0 Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52 53 55 56 61 62 72 77 VIN: WAUDG74F25N068991 Mileage: 178200km/110728miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: Cannot be reached 1100 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: Cannot be reached 1100 0F-Digital Radio -- Status: Cannot be reached 1100 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: Cannot be reached 1100 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: Cannot be reached 1100 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: Cannot be reached 1100 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: Cannot be reached 1100 ------------------------------------------------------------------------------- Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl Part No SW: 4F1 910 559 B HW: 4F1 907 559 A Component: 3.2l V6 FSI 0040 Revision: --H15--- Serial number: Coding: 01050106190F0120 Shop #: WSC 02335 785 00200 VCID: 2A50CDCBFC6F 1 Fault Found: 18975 - Low Pressure Fuel Sensor (G410): Intermittent P2543 - 009 - Open or Short to Ground Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 254 Reset counter: 40 Mileage: 170038 km Time Indication: 0 Date: 2011.01.31 Time: 11:07:30 Freeze Frame: RPM: 1312 /min Mass Air / Rev.: 223.5 mg/str Temperature: 94.5°C Part Throttle Pressure: 4.9 bar Speed: 63.0 km/h Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4F1 910 156 H HW: 09L 927 156 Component: AG6 09L 3.2 FSI USA 0020 Revision: --H01--- Serial number: 0065172 Coding: 0001002 Shop #: WSC 02335 785 00200 VCID: 295232C7F969 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4F0-910-517.lbl Part No SW: 4F0 910 517 E HW: 4F0 614 517 A Component: ESP8 quattro H03 0010 Revision: 00000000 Serial number: 00000000000000 Coding: 0020895 Shop #: WSC 02335 785 00200 VCID: 264839FBE877 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 ELV H30 0130 Revision: 30040401 Serial number: 10600300083552 Coding: 0000011 Shop #: WSC 08256 444 66570 VCID: E3CEE0EF5BC5 Part No: 4F0 910 131 J Component: FBSAUDIC6 EZS H43 0070 Part No: 4F0 910 220 A Component: FBSAUDIC6 IDG H01 0040 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Cannot be reached ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4F0-910-043.lbl Part No SW: 4F0 910 043 HW: 4F1 820 043 J Component: KLIMABETAETIGUNGH11 0110 Revision: 00000023 Serial number: 00000000077978 Coding: 0524326 Shop #: WSC 02335 785 00200 VCID: DBBED80F63B5 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 HW: 4F0 907 279 Component: ILM Fahrer H14 0080 Revision: 00000000 Serial number: 4F0907279 Coding: 0013123 Shop #: WSC 02335 785 00200 VCID: E6C8F9FBA8F7 Part No: 4F1 910 113 Component: Wischer AudiC6 H05 0150 Coding: 00062736 Shop #: WSC 02335 Part No: 4E0 910 557 Component: REGENLICHTSENSORH10 0050 Coding: 00141886 Shop #: WSC 02335 1 Fault Found: 01498 - Bulb for Parking Lamps; Right (M3) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 2 Fault Frequency: 215 Reset counter: 205 Mileage: 172856 km Time Indication: 0 Date: 2011.03.04 Time: 09:01:00 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Cannot be reached ------------------------------------------------------------------------------- Address 0F: Digital Radio Cannot be reached ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4F0-910-655-8R.lbl Part No SW: 4F0 910 655 B HW: 4F0 959 655 A Component: 56 AIRBAG AUDI8RH29 0310 Revision: 10H29000 Serial number: 00359D080JFT Coding: 0013622 Shop #: WSC 08256 444 67494 VCID: 264839FBE877 Part No: 4F0 910 339 Component: BF-Gewichtsens. 002 0040 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 HW: 4F0 953 549 A Component: Lenksäulenmodul H07 0230 Revision: 00H07000 Serial number: 90055042960003 Coding: 0002041 Shop #: WSC 02335 785 00200 VCID: E6C8F9FBA8F7 Part No: XXXXXXXXXXX Component: Lenkradmodul H05 0080 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4F0-910-xxx-17.lbl Part No SW: 4F0 910 900 A HW: 4F0 920 950 M Component: KOMBIINSTR. M73 H09 0460 Revision: 00300000 Serial number: 4I210JNA4 Coding: 0065203 Shop #: WSC 08256 444 54176 VCID: 1E38111BB027 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4F0-910-468.lbl Part No SW: 4F0 910 468 A HW: 4F0 907 468 B Component: Gateway H09 0030 Revision: 09 Serial number: 0800804A180321 Coding: 6CFE73CC1B3904 Shop #: WSC 08256 444 59217 VCID: 275634FFEF7D 2 Faults Found: 00384 - Optical Databus 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 217 Mileage: 177631 km Time Indication: 0 Date: 2011.04.27 Time: 20:30:04 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 203 Mileage: 177228 km Time Indication: 0 Date: 2011.04.22 Time: 12:04:39 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4F0 910 760 HW: 4F0 959 760 Component: Sitzmemory FS H04 0050 Revision: 00000000 Serial number: 00000000896400 Coding: 0082946 Shop #: WSC 02335 785 00200 VCID: E1C2EAE741D9 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Cannot be reached ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl Part No SW: 4F0 910 793 B HW: 4F0 959 793 B Component: TSG FA H10 0020 Revision: 00000000 Serial number: h0 Coding: 0035563 Shop #: WSC 02335 785 00200 VCID: 295232C7F969 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4F0-910-289.lbl Part No SW: 4F0 910 289 E HW: 4F0 907 289 E Component: Komfortgeraet H14 0090 Revision: 00900014 Serial number: 01001399920000 Coding: 0424125 Shop #: WSC 02335 785 00200 VCID: 2C5CCBD3F69B Part No: 1K0 951 605 C Component: LIN BACKUP HORN H02 1301 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Cannot be reached ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 A Component: ILM Beifahrer H09 0050 Revision: Serial number: 00000000042520 Coding: 0001114 Shop #: WSC 02335 785 00200 VCID: DEB8D11B70A7 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl Part No SW: 4F0 910 793 B HW: 4F0 959 792 B Component: TSG BF H10 0020 Revision: 00000000 Serial number: 0 Coding: 0035563 Shop #: WSC 02335 785 00200 VCID: 295232C7F969 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4F0-910-801.lbl Part No SW: 4F0 910 801 HW: 4F0 907 801 Component: EPB C63C0030 H03 0030 Revision: C63C0030 Coding: 0005022 Shop #: WSC 02334 785 00200 VCID: DDBAD6177DA1 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4F0-910-357.lbl Part No SW: 4L0 910 357 HW: 4L0 907 357 Component: AFS 1 H01 0040 Revision: 00000001 Serial number: Coding: 0000016 Shop #: WSC 08255 444 178146 VCID: E9D2F2C7B9E9 Part No: 4F0 941 329 A Component: AFS-Modul links H05 0010 Part No: 4F0 941 329 A Component: AFS-Modul rechtsH05 0010 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4F0 910 181 E HW: 4F0 915 181 A Component: ENERGIEMANAGER H11 0400 Revision: 00000000 Serial number: 00000000073491 Shop #: WSC 25807 444 57975 VCID: 234E20EF9B45 Part No: 4F0 915 105 C Component: von VA0 4410190823 Coding: 344630393135313035432056413034343130313930383233 Shop #: WSC 00000 384 00290 5 Faults Found: 02256 - Quiescent Current 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 7 Fault Frequency: 3 Reset counter: 206 Mileage: 175189 km Time Indication: 0 Date: 2011.03.28 Time: 13:19:16 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Mileage: 173718 km Time Indication: 0 Date: 2011.03.15 Time: 18:29:17 02276 - Quiescent Current Stage 5 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Mileage: 173718 km Time Indication: 0 Date: 2011.03.15 Time: 18:29:28 02274 - Quiescent Current Stage 3 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Mileage: 173718 km Time Indication: 0 Date: 2011.03.15 Time: 18:29:38 02277 - Quiescent Current Stage 6 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Mileage: 173718 km Time Indication: 0 Date: 2011.03.15 Time: 18:29:48 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 HW: 4F0 959 795 Component: TSG HL H09 0010 Coding: 0035370 Shop #: WSC 02335 785 00200 VCID: E9D2F2C7B9E9 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 HW: 4F0 959 794 Component: TSG HR H09 0010 Coding: 0035370 Shop #: WSC 02335 785 00200 VCID: E9D2F2C7B9E9 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Cannot be reached End --------------------------------------------------------------------- |
All those 'Cannot be reached' says there is a break in MOST loop to me.
Probably before or after the radio. |
i assume the break is in the control head since it talks to all the units.
Originally Posted by jakematic
(Post 24140052)
The CAN Gateway is actually the master ringleader in the MOST system, but any one of those modules could be causing the problem. Run the [Optical Bus Diagnostics] function found in the Applications Screen and save the results.
http://www.ross-tech.com/vcds/tour/optical-bus.html |
Update:
When i started the car yesterday morning, everything was working fine. The only thing different that icould notice was that sirus changed thier channel line up. No sure if my reciever got stuck in some sort of data upload and caused a system failure; but currently everything is working fine. |
Originally Posted by 05whtaudia6
(Post 24140725)
Update:
When i started the car yesterday morning, everything was working fine. The only thing different that icould notice was that sirus changed thier channel line up. No sure if my reciever got stuck in some sort of data upload and caused a system failure; but currently everything is working fine. everything is working well; only thing i could do is wait to see if this happens on a rainy day again. so here is the optical test: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Control Module Part Number: 4F0 910 468 A Component and/or Version: Gateway H09 0030 Optical Bus Diagnostic : Standard Controller Electrical Optical 19-CAN Gateway OK OK 07-Control Head(High/D3) OK OK 0E-Media Player 1 OK OK 77-Telephone OK OK 47-Sound System OK OK 56-Radio OK OK 37-Navigation OK OK 0F-Digital Radio(SAT) OK OK ************************************************** ********** and the recorded errors 02244 - Button in Control Head is Stuck 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 5 Fault Frequency: 3 Reset counter: 40 Mileage: 176083 km Time Indication: 0 Date: 2011.04.09 Time: 18:15:13 Freeze Frame: Bin. Bits: 00000000 Bin. Bits: 0100000 Bin. Bits: 100 00384 - Optical Databus 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 40 Mileage: 177631 km Time Indication: 0 Date: 2011.04.27 Time: 20:29:34 02024 - Perform Adaptation 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 5 Fault Frequency: 35 Reset counter: 199 Mileage: 169052 km Time Indication: 0 Date: 2011.01.13 Time: 18:03:40 02927 - DVD Read Error 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 6 Fault Frequency: 3 Reset counter: 239 Mileage: 177630 km Time Indication: 0 Date: 2011.04.27 Time: 20:26:36 Freeze Frame: Hex Value: 0x4DC3 Hex Value: 0x8647 Hex Value: 0x04FF Hex Value: 0x0000 Address 47: Sound System Labels: None Part No SW: 4F5 910 223 F HW: 4F5 035 223 E Component: DSP-High C6 H14 0330 Revision: PROD_01 Serial number: 00000000013088 Coding: 0000016 Shop #: WSC 02335 785 00200 VCID: 264839FBE877 1 Fault Found: 02095 - Component Protection Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 242 Time Indication: 0 |
