Comfort Turn Signal
Comfort Turn Signal
I would like to increase the "blinks" the comfort turn signal makes from 3 to 5 in my 2010 Audi Q5 3.2.
I think I have searched most of the options on my VCDS but have been able to find coding.
Any advise would be appreciated!
MarinellI (02-24-2020)
46/Control Module System Comfort > Adaptation > Turn Signal Control: Freeway flashing cycles > 4 (old value 3)
I have located:
+32768 = Highway/Comfort Turn signals
under module 46-Central Conv in a yellow pop up window with a number of other options starting at +00001 and doubling with each option until it reaches the last option of Highway/Comfort Signals
How do I change the value.
46 central conv.
Adaption
Turn signal control-freeway flashing: flashing cycles
Old value is 3 (for 3 blinks)
I changed it to 4
* this is what I have saved for my Q7.
Thanks but my adaptation in 46 does not have the option.
I can see what I want to change in a yellow pop up window in Personalization key option but I don't know how to program the personalization key to identify the Highway Turn Signal option.
This field is called a bitmapped field. Basically, you have to add all the options you want and that gets you the value to set. So, right now, your value of 53730 means 2+32+64+128+256+4096+16384+32768. Normally these are used for yes/no fields, so I'm not sure how you'd set a counter for flashing here. This may just allow you to turn the function on/off.
RxFX101
11-17-2004 12:32 PM
A42.0rgy
11-24-2002 08:33 PM
