Audi Fault Code P0741-17125 100 % Fix
The Audi has become well known as a fine automobile, unfortunately the transmission continues to be a problem. Even when overhauled, the same factory parts are installed resulting in the same problems. LEVEL 10 has developed a series of valve body & torque converter components and modifications that will correct code P0741-17125 and transmission failures. The best part of our modifications is there is no need for a complete transmission overhaul saving thousands of dollars. Send LEVEL 10 your valve body & torque converter and we will perform all the necessary modifications for just $1298.00, or drop off your car and we will do it with a complete transmission service for just $1998.00 Some are higher. Most work can be performed in a 2-3 days, with a loaner car available through appointment. Don't wait for the tranmissions to fail, you can save it now with just a phone call to our service department. Contact LEVEL 10 and Feel the Power Now! 973 827 1000 info@levelten.com |
