The ECS B7 A4 2.0T Luft-Technik Front Mount Intercooler has arrived!
Performance is all about keeping cool, especially for forced induction engines. Heat and restricted airflow are our enemies. The new ECS Intercooler and Charge Pipe kit for your B7 A4 fights back with the efficiency and cooling your engine needs to regain some of that power lost to the factory counterpart. With our intercooler, you can expect lower intake air temperatures by up to 17 degrees and experience a 26% increase in intercooler efficiency. All this is good for a hearty WHP gain from a direct bolt-on upgrade. Keep your B7 A4 cool this summer with the ECS intercooler kit.
ECS B7 A4 2.0T Luft-Technik Front Mount Intercooler http://ecsmedia.ecstuning.com/Audi_B...R_17623_01.jpg Audi B7 A4 2.0T https://c1552172.ssl.cf0.rackcdn.com/1318295_x800.jpg https://c1552172.ssl.cf0.rackcdn.com/1318313_x800.jpg Max power gains of 12 WHP and 12 WTQ Reduced intake temperatures and air turbulence Increased air flow capacity Up to 26.2% improved intercooler efficiency on a stage 1 tune 5 back to back pulls on dyno showed only a 1.7 F increase in intercooler outlet temperature 16.9 F total reduction in temps compared to stock Substantially less pressure drop across intercooler Cast aluminum intercooler end tanks Bar and plate design intercooler core 60mm diameter charge pipes for increased flow Upgraded Derale power steering cooler with custom relocation bracket Charge pipes are constructed of CNC mandrel bent 6063 aluminum tubing Includes stainless steel t-bolt clamps, silicone couplers, and all necessary hardware for installation Easy and direct replacement upgraded intercooler ECS B7 A4 2.0T Luft-Technik Front Mount Intercooler |
