The ECS B7 A4 2.0T Luft-Technik Front Mount Intercooler has arrived!
Audiworld Basic Sponsor
Performance is all about keeping cool, especially for forced induction engines. Heat and restricted airflow are our enemies. The new ECS Intercooler and Charge Pipe kit for your B7 A4 fights back with the efficiency and cooling your engine needs to regain some of that power lost to the factory counterpart. With our intercooler, you can expect lower intake air temperatures by up to 17 degrees and experience a 26% increase in intercooler efficiency. All this is good for a hearty WHP gain from a direct bolt-on upgrade. Keep your B7 A4 cool this summer with the ECS intercooler kit.
Audi B7 A4 2.0T
Max power gains of 12 WHP and 12 WTQ
Reduced intake temperatures and air turbulence
Increased air flow capacity
Up to 26.2% improved intercooler efficiency on a stage 1 tune
5 back to back pulls on dyno showed only a 1.7 F increase in intercooler outlet temperature
16.9 F total reduction in temps compared to stock
Substantially less pressure drop across intercooler
Cast aluminum intercooler end tanks
Bar and plate design intercooler core
60mm diameter charge pipes for increased flow
Upgraded Derale power steering cooler with custom relocation bracket
Charge pipes are constructed of CNC mandrel bent 6063 aluminum tubing
Includes stainless steel t-bolt clamps, silicone couplers, and all necessary hardware for installation
Easy and direct replacement upgraded intercooler
Audi B7 A4 2.0T
ECS Tuning-Audi
A4 (B7 Platform) Discussion
05-29-2019 01:14 PM
ECS Tuning-Audi
A4 (B9 Platform) Discussion
04-09-2019 09:44 AM
ECS Tuning-Audi
01-20-2017 05:47 AM
ECS Tuning-Audi
A4 (B8 Platform) Discussion
01-16-2017 01:38 PM
ECS Tuning-Audi
09-05-2014 11:46 AM
