1990 Audi 100 Speedometer problems
recently my speedometer stopped working so i figured the speedo itself or something in the cluster was messed up so i pulled it completely out and checked over all the solder points on the speedo and the cluster electronics, it all looked fine so i figured it might have been the speed sensor, i replaced that and still no luck, at this point im thinking the wiring from the the sensor to the speedo may be shot?, what do u guys think?
Audiholic
Re: 1990 Audi 100 Speedometer problems
The .10 mile wheel has broken free from the shaft and spins freely instead of turning the next mile when it goes beyond the .9. This has been a common problem with Audi's for 20 years that I know of. I have fixed them, but you need to completely disassemble, and arefully epoxy, of superglue the white wheel to the common shaft. Be careful not to let glue go elsewhere
Ben's e//S2
02-14-2002 09:24 AM
