2002 A6: Wheel or Tire too large? Help!
i recently bought a new set of these after doing research that they would fit my 02 A6 Quattro. I had 235/50/17's mounted but they're now hitting the spindle on the front so bad that they can be driven (until I get spacers?).
Normal tire height for this wheel is 235/45/17 but I wanted to know if anyone has put a setup close to this on their C5 and if so, what width spacer did you use for front and back? Is there a method to how you measure (aside from just measuring the rim hub to the outside)
Thanks!
We would sell you a wheel around ET35, so a 10mm spacer should get you where you need to be. We do not sell spacers, however, so you'll need to make sure that the company you are buying from has a good return / exchange policy in case 10mm is not enough.
At this point, Im just trying to figure out if a 15 or 20mm would work to put the wheel far enough away from the suspension and keep it within the fender well.
Thanks for replying.
baubau2.7
08-16-2014 09:22 PM
A6TwinTurbo
Wheels & Tires Discussion
08-23-2001 03:51 AM
