2016 A5 S line wheel/tire change
I did a quick search - found lots yet no specifics to my issue.
OE rims/tires on the car are 245/40/18, 8.5 x 18 ET29. I'm looking at a set of 245/35/19, 8.5 x 19 ET 40. The tire/rim calculator says inner clearance 11mm less, outer position retracted by 11mm, diameter difference .04" (.14%).
So I need help understanding if the 19" will fit with no issues. Is the calculator saying the new set will move inward by 11mm?
Thanks!!
Thanks!!
Former Vendor
Correct - the front lip of the 19x8.5 ET+40 will sit 1/2" further inward when compared to where the front lip of the O.E. wheel sits now. The inside lip of the wheel will also sit 1/2" closer towards the suspension when compared to your O.E wheels.
The new combination should fit just fine, assuming the other wheel specs are appropriate (I.E bolt pattern, center bore, etc).
S4Dean
23
10-31-2007 05:35 PM
Audi S5 TC
Wheels & Tires Discussion
01-14-2006 07:06 AM
Tomasz@Startup
A4 (B7 Platform) Discussion
12
01-03-2006 02:16 PM
drgolfnut
05-03-2005 06:07 PM
Reg Dunlop
9
12-31-2004 02:02 PM
