Bore size of Sport Edition SE-14 18in.
Bought them off someone with an S3 for my winter beater set. It seems to have the wrong size hub ring and later found out he mounted them to his S5 before selling them. Since S3 and S5 have different center bore size, the center ring on the wheel doesn't fit the S3 anymore and I noticed vibration when going above 60.
The guy originally bought them from Tirerack I believe. If someone from Tirerack sees this, please let me know if you guys will sell lugnuts for this wheel? The shop I went to overtorqued the lugnuts, I stripped 2 of them trying to take them off at home.
https://www.tirerack.com/wheels/Whee...6&autoModClar=
My car is a 2016 S3.
Thanks!
Thanks!
Not all Sport Edition wheels are manufactured by the same company, so the bore diameter will be either 73mm or 72.2mm, so you may want measure. Some rings will have the OD stamped on them as well, so worth a look
Do you happen to know the lug nut part# of those rims and how I can order a few spares from Tirerack?
I measured it. The rings had no measurements on them so I am just going to say 73mm.
After a little more digging, I'd bet your centerbore is 72.2mm.. Our (internal) part number for the bolts is B13 and KSE571X for the rings.
Feel free to call in an order as we do not offer small parts online
Arch57
12-05-2002 07:04 AM
RD48SEC
06-06-2001 03:58 PM
