Fitting tts rims on A4
Tire size is fine, but TTS uses around at 45+mm offset and newer A4 should be closer to 40mm (so you may need a small spacer). The TTS hub is 57.1mm and A4 uses 66mm so the A4 hub won't go into the centerbore drilled in the Original Equipment TT wheels. If it is an aftermarket wheel (that uses a centering ring), you may be OK to just get new rings.
Zach, USM
Wheels & Tires Discussion
07-25-2003 06:16 AM
ex-quattro PETE
03-11-2002 08:28 PM
