HELP~~ 245/40ZR18 on 18" for my 02 A6 3.0? Safe?
Recently i got a set of 18" with 245/40ZR18 on it. I am afraid to put it on my car. Any suggestion?
Please help~~~~ Regards |
Re: HELP~~ 245/40ZR18 on 18" for my 02 A6 3.0? Safe?
These are a bit larger than we typically use on the car and may rub, but it is a borderline fitment so they just might work. Bolt them on and check clearances carefully before driving on them.
Gary Thank you for the reply,
so if i change only the front two tires to 235/40-18 or 225/40-18 and keep the 245/40-18at rear,is it works? And which size u think is my best choice? Thanks |
All four tires must be the same size. I would prefer to see you in size 235/40R18 as we know that this size works well.
Thank you so much Gary~~~~~~~~~~~~~~~
Thank you so much Gary~~~~~~~~~~~~~~~ Thank you so much Gary~~~~~~~~~~~~~~~ Thank you so much Gary~~~~~~~~~~~~~~~ |
