tire gurus: tire wear on outer edge - what is it?
I'm getting considerably uneven wear on outer edge of two front tires on my 2007 Q7. Is this misalignment, wheel balance, inflation pressure, other? Is it a tell tale sign of a single specific issue? If so, what is it?
thanks
thanks
Also incorrect toe will wear the outsides of the tires faster (alignment)
Also, crank the steering wheel all the way left and right to check the insides of the tires. If the insides are worn too then it's low pressure that's most likely the culprit.
C-Nutts
Wheels & Tires Discussion
12-10-2003 02:23 PM
STXPRESS
10-23-2002 06:24 PM
Gary@Ronal
11-09-2000 03:34 PM
