What damage can occur by using ball shaped lugs in a wheel requiring conical?
I have ordered new conical lugs, but I'm just wondering if I need to put the OEM wheels back on until the new lugs get here?
AudiWorld Expert
cracked wheels
You are putting the load of the wheel on to a smaller area than was designed. This means more stress when a bump or dip occurs.
AudiWorld Expert
You will be able to see them when you take the wheels off.
You should be OK unless you really had been driving the car hard
Good decision as if it was my car I would be putting on the other wheels till I got the correct bolts
Hopefully they'll be okay...
I've just driven on them for about 30 miles and I have a 15 mile trip home... All Interstate and highway driving. I sure hope I don't have cracked wheels after only 45 miles, but I'm sure anything is possible with the wrong equipment. The wheels I got from Projektzwo a few years back came with lugs. I wish they would specify the needs of the wheel if they aren't going to provide the hardware. I've now ordered hubcentric rings and new lug bolts.
Former Vendor
Yep.. Worst case
You're putting a hard cold forged steel bolt into a soft aluminum wheel. Usually you'll just get a small dent on the seat of the wheel, under rare circumstances you could crack the wheel.
