WHEEL FITMENT FOR 2006 B7
Hey Gary,
I really appreciate your prompt replies.
I stalled on ordering rims because my car started having trouble. Turns out it was a cracked vacuum hose and was fixed under warranty. I was tripping out that it might be my transmission because I read it on the forum right before my car started acting weird.
Anyways, I just wanted to do a final check before I get my rims!!!!! YAY!!!
I decided not to stagger and get the same size rim on all four.
18 x 8.5, et30, bolt pattern 5x112, with 235/40 tires. Will these fit?? O and I have Tein coilovers.
THANKS AGAIN GARY
If you give me the go, I'll order them!!!
THANKS AGAIN GARY
Re: WHEEL FITMENT FOR 2006 B7
18X8.5 ET30 is a little aggressive for a lowered car (close to the fender, may rub or require fender lip modification) 18X8 or a higher offset would be more likely to fit without problems.
Thanks for your reply...
I'm just rying to get the most aggressive setup.
I've been hearing so many different things and I still have some questions regarding the most aggressive setup for a b7 quattro.
Can i get 18x8.5 et 35 up front and 18x9 or 9.5 et 35 on back and just wrap it with the same size tires?
If not, please suggest me a proper fitment..
Thank you. I want it to look somewhat like the black a4 wagon in this thread
Thanks!!!<ul><li><a href="http://www.audizine.com/forum/showthread.php?t=118912">http://www.audizine.com/forum/showthread.php?t=118912</a</li></ul>
