Wheel spacer - what is the smallest one that will still give me hub centricity?
Not an answer, but maybe a datapoint helps..
Hi Mike,
I'm not sure that I understand your question -- it seems like it ought to be "what is the largest one that will still give hub centricity?" Anyway, I'm running 5mm H&R spacers front and back during the winter, and they are hub-centric. I believe that all the H&R spacers are hub-centric, but they accomplish it in 2 different ways.
The thinner ones, and the 5mm is in this category, just have a 57.1mm center cut-out that the hub pokes through. My A4 has plenty of hub, so it still makes good contact with the wheel itself.
The thicker spacers have what amounts to an extension of this inner part of the hub, so the wheel makes contact only with the spacer, and not with the hub itself. The whole setup is still hub-centric though.
I don't know where the thickness cut-off is between these 2 styles. Depends on application maybe? I didn't like the idea of using the thicker style spacer (just another piece of machining tolerances to rely on,) but 5mm works great with my winter wheels, so not an issue for me.
I guess this was a long-winded way of saying you can probably get a conclusive answer from either Roland at H&R, or Eddie who sells them :-)
Hope this helps a little.
D Spin
Wheels & Tires Discussion
05-17-2006 08:26 PM
ePuFFy
15
06-10-2005 01:32 PM
unc99206
05-12-2005 05:16 AM
djnelsen
04-17-2002 02:05 PM
