Winter tires on 2018 Audi A6 Technik - AudiWorld Forums
Go Back  AudiWorld Forums > Technical Discussion > Wheels & Tires Discussion
Reload this Page >
Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Sponsored by:
Sponsored by:
Old 11-10-2018, 03:34 AM
Default Winter tires on 2018 Audi A6 Technik
I'm finding conflicting information in reagards to what tires and rims I can out on my 2018 A6 Technik. I currently have 255-40-19R all season tires, and I would like to go down to 17's for the winter. Some shops say I can but other's say it's 19 minimum. I tend to believe that as the disks and calipers will be too big for 17's?
rickythestick is offline
Old 11-10-2018, 03:58 AM
btw, inside the door, it's 255 40 19R...
Old 11-10-2018, 05:20 AM
uberwgn's Avatar
Rick, welcome aboard!
If you open the Owner's Manual, tire inflation pressure section, you'll find a list of the various tire/wheel sizes that work on your car. I'd also check at forum sponsor, Tire Rack, for alternate (minus) sizes that will work.
uberwgn is offline
Old 11-10-2018, 06:33 AM
thanks for the info. The problem with tire rack is that they don't have the "Technik" as an option for that model. Do you know the equivalent of Technik in the US by chance? thx!
Old 11-10-2018, 08:30 AM
raj99's Avatar
Rick "technick" is simply an options designation and is equivalent to the Prestige here in the states.
The platform, C7, is the the same.... Your only concern should be wheel clearance over your calipers and rotors.
I know for a fact that a 18" wheel will work for you, but not 100% certain about a 17
raj99 is offline
Old 11-13-2018, 12:02 PM
Thanks for the info guys. 17's don't fit but 18's do. The 18's I'm looking at however are 18X8 as opposed to the 19X8.5 that are currently on the car. When I plugin these numbers into willtheyfit.com, I get this message: Compared to your existing wheel, this new wheel will have an inner rim which is 6.3mm further away from the suspension strut. The outer rim will poke out 6.3mm less than before.
Would 6.3MM be an issue? Seems like a very small difference
Old 11-13-2018, 12:23 PM
raj99's Avatar
you failed to mention one key piece of information. What is the offset on the new wheels vs. the old wheels.
6.3MM is hardly anything - about 1/2 CM, so I wouldn't even sweat that.
raj99 is offline
Old 11-13-2018, 12:30 PM
Same offset, both 45
Old 11-13-2018, 02:01 PM
raj99's Avatar
you'll be fine...like I said before.
raj99 is offline
TheElevendude
S4 (B8 Platform) Discussion
03-01-2018 03:29 PM
carfanaticA4
12-06-2017 03:36 PM
Quick Reply: Winter tires on 2018 Audi A6 Technik
