- Audi A5 TDI Raised Idle
- Self Repair or Mechanic?
- 2011 Q5 3.2 Head Gasket Replacement
- Dealer/Salesperson Rec
- What to ask when buying a used moter for My 2011 Audi A-4 2.0
- DAB radio problem on 2014 Audi a1
- Unsure about a regular mechanic putting engine in my Audi
- Audi 2012 A4 Premium heating and cooling problem help please.
- C8 Audi A7 S-Line mods
- mmi problem
- AUDI A4 B8.5 big problem
- AUdi Cabriolet 1996
- Cluster Display Issue
- Drivers door on my Q5 opens when in the garage sitting idle
- 2012 Audi A6 Quattro 3.0 EPC check engine light no crank
- Just a new guy
- Head Up Display Audi Q7 2021!
- Q5 2011 lower door mouldings
- new to me audi rs 7
- 2014 audi a6 3t PROBLEMS PLEASE HELP!!
- New Audi owner in Virginia
- Ecu swap audi a3 8p
- Dears Mods, can't upload picture?
- New member in Austin
- What’s the name of the Audi Q7 part
- Bad Sound out of Audi A4 B8.5
- BA: Audi Q5 2010 wrong language showing when English Language is selected
- Audi A6 50 TDI quattro Rattling noice
- AUDI 5 SPORT BACK S-LINE
- Water spots won't come out on Q7
- 3.0L a6 swap in a OBS Chevy rclb
- vacuum source
- Do i have a faulty injector? Help appreciated
- Customizing balck A4 black optic package?
- Ambient lighting not working
- 2007 S8 D3 V10 BSM Air Maff wiring diagram l need help
- slim gummies
- Interested to buy a 2019 tt 40 tfsi
- 2022 Q7 EPC correction
- Starter replacement bolt help
- 2017 B9 A4
- Audi TT 2018
- A8 A/C issue after harmonic balancer gave out
- Do these breaks need to be replaced?
- A6 C5 Interesting Transmission Problem
- Long time listener, first time caller...
- Refuse to troubleshoot
- Hello New SQ8 owner.
- Audi Q7 air filter
- Pls help don’t know what to do!!
- Engine start system fault Audi A6
- IE: Smoke coming engine from time to time: Audi B8 2.0 diesel 2010
- Q5 oil change dilemma
- Audi SQ5 coding for Audi Drive Select
- 2015 Audi Q7 rust on dashboard grill
- A4 b9 2.0 tdi
- Audi A7 2016 diesel quattro
- UK: Audi A6 C6 2.0 diesel timing?
- Chemical Smell 2024 Audi Q5 Plug-In Hybrid
- LV: Question about HPFP Audi A4 B5 (1.9 diesel, 81kw)
- 2004 Audi A8 4.2 Northern Blue Pearl Effect w/Black
- 2011 Audi s5 EPC light on
- 2017 A3 e-tronic crossover hatchback
- 2023 Audi S8 Fuse Amperage Allocation for all boxes
- PLEASE help, Audi A4 SLine
- Possible 2011 R8 V8 ownership
- Another Audi issue
- Audi A8 TDI 2015 148,000 miles front camera issue
- Another new member.
- Bought one of my dream cars today.....
- A4 B8 2009 2.0T 6Speed stutter which causes miss on cylinder 3
- A4 B8.5 No sound on all left speakers
- 2018 q7 P21a1 error
- Hi again
- A7 water pump
- The wavy washer found in my engine?
- How to format Navigation database MHI2Q
- PL: przywitanie...
- Audi 5F coding 2018 Q5
- Trying to diagnose a seemingly difficult issue... Please read and help if can
- IT: I introduce myself
- Please help with this Noise
- Audi misfire at idle
- JLB44
- MK: Audi a7 2012 3.0 diesel
- UK: oil leaking from a hose 2005 TDI 2.0 BKD
- How to change with VCDS the VC display from A5 sportback to RS5 sportback ?
- Knocking sound and and shake(like car go up)when turn on engine.(Maybe transfer case)
- What's with the FILTHY rocker? 2024 S5
- 2017 | Q7 | Front Doors | Errors: b122d29, b122b13
- UK: Audi A1 2022 plate steering gone caused car crash
- Aud wheels FY and 8R direct fit?
- IT: New member
- '17 A4 - Transmission Malfunction - DTC P07B600
- automatic transmission problem
- Rear view camera wont display A5 B8.5 8T
- APR ECU for A5 Sportback 2023
- 2016 Audi A6 quattro premuin plus 2.0
- 18 A3 stage 2+ suggestions
- A3 Halogen lights to LED
- Prestige vs. Technik trim package for 2019 Q5
- Audi S5 B9 - Drive System Malfunction - P0243
- Newbie from Northern California
- 2014 Audi q5 2.0 eating o
- Hi everyone! I'm new here!
- Audi Q8 SOS Fault
- Misfire issue - Audi A4 cabriolet 1.8T B7 petrol
- New Member, 1997 Audi help
- New Member - First Audi
- 18 Q7 Do I need an alignment?
- 2020 Audi Etron Coolant Leaking Seal Failure
- New member from Durham, NC
- NEED SERVICE IN CHARLOTTE.
- Jump in Transmission when coming to a stop ?
- New A6 member
- Audi A1
- new user of future Q5
- High volume North East dealer to order an rs3?
- 2006 audi a8l NEED HELP PLEASE
- Q7 vibration at 1100 to 900 rpm.
- Too much oil added
- New to the forum, not new to Audi
- New to forum, Not New to Audi
- Audi a6 c7 3.0 tdi 245ps
- New but not New
- Want to know how many 2007 S4 cabrios made with 6 speed manual please.
- New Member - wheel recommendation?
- It only took 23 years to buy myself an Audi
- What type of transmission in 2016 S6 PDK is the sticker code in the build sticker
- UK: 100 C3 model
- Audi A3 cabriolet rear seat doesn't release
- 2024 S4 Order Silence
- New Member Here. Hello to All Fellow Members!
- overheating issue
- Airlock? No start
- 2010 Audi Q7 TDI fault codes/VCDS diagnostic log (egine, ABS, radi0, etc.)
- I'm new around here!
- HELP! Audi Q7 TDI Leak
- ESP/ABS malfunction
- 2018 Audi 20 inch rims 8.5 inch vs 20 inch 9.0 inch
- NO: How rare is this steering wheel? I cant find any information on it..
- MMI and app issues Q5 2023
- Finally Joined 2018 Q5
- New member
- Hellooo new A8 member here
- Audi A8 D4 engine not heating up
- Intro
- New A4 owner from PA USA
- USB Stopped working
- Help"""""
- A4 b8 2.0T ecu damage
- New to Me 2021 Q5
- (2008 Audi A4) Accidentally left passenger window cracked during snow storm, passenge
- New to me Audi Q5 2.ot
- New (to me) Audi Owner
- EPC Light and engine shut down
- Audi A3 8V Wheel Fitment
- HELP PLEASE A6 C6 3.0TDi semi auto
- Turns out 2023 Allroad is -- So-So At Best
- **Please Help*** Fault Code U141100
- Audi q8 50 tdi 140k km
- Hey everyone!
- Audi SQ7
- New audi owner
- 2011 Q7 towing a travel trailer
- radio not installed
- 2010 A6 Quattro supercharged check engine light after oil change
- New Member Urgent CPO Certified Question
- Transmission issue? Car not moving in drive or reverse
- audi a4 b7 fuel problems
- q5 turbo charging
- Knocking sound on the back of audi a4 2006
- Hola From Mexico
- A8 D4 stop light
- Total Audi noob looking for tuning advise.
- Presentation
- Audi pure protection and tire protection warranty
- Opinion on aftermarket parts from shop
- Audi A6 Blown Power Steering Module
- 2017 Audi A4 System Malfunction with No Codes
- RS5 vs S7
- 201p 4a front doors
- 2010 8RQ5 fuel filter undertray/cover tow bar part number
- audi a7 2012 gearbox stuck car wont start
- Looking for info on ie mobile flashing
- USB Issues
- 2014 A4 B8 2.0 - Lean Code CEL + High Positive LTFT
- Hello from Italt
- Q5 Panoramic Sunroof noises
- Audi Q7 2008 AFS and range control What is the differene?
- Part number for centre sliding cover
- Hello from france !
- Replacing MP3 Audi A4 B6 2003
- Hello everyone!
- 2019 Audi Q8 Braking
- 2009 adui a4 2.ot misfiring
- U
- Australian Q7 Dead on Arrival After Battery Change
- Misfires after changing fuel pressure sensor.
- Generator/alternator location
- Oil Leak Clean Up
- New car, whats this?
- PK: A New Comer
- Customer service and long order time
- Defective alternator in Q7 2021
- HELP Audi MMI/AMP problems
- UK: fail or pass, GLOW PLUG
- Cr injector
- Changing Interior Color on RS Q8
- Playing music in 2012 Audi Q5
- Need help identifying part on 2002 Audi tt 1.8l
- Electronic Power Steering Module No Communication
- Q5 audi fuse box locations?
- 2009 Audi TTS Flickering interior lights
- Bypassing thr ECU and CANbus for power seats
- Audi warranty decline on camera
- EPC LIGHT ON MY AUDI A4 SLINE
- 2016 Audi S6 oil change caused hydro lock
- New Member
- 1987 Audi 4000 cut out at 3200 rpm
- north wales guy with launch & Mr.T background
- New member torn between '18 RS5 and '22 RS3
- Swapping standard cockpit to virtual Audi A4 B9
- Audi A6 C6 3.0 TFSI - Should I buy one? (LONG THREAD)
- Replacement of blind spot module A8 D4
- Audi to BMW Wheel hub
- Shipping Audi from US to Germany?
- About parts supply.
- Audi A6 C6 drivers window fault
- Alaska. Q7 noob
- Rear Turn/Brake Light Control Module
- REMOTE START
- S3 8p misfiring
- WTB b5 S4 Avant
- Temp Gauge Stuck on Cold...No Codes
- HU: Best exhaust for the B9 SQ5 in Europe?
- 24 Q8 Etron SOS red light error
- Technologist Here
- 2022 Audi Q8 Premium
- ZA: Armaspeed Carbon Intake
- New owner
- New Member
- 2018 audi s6 4.0T
- Bonjour
- Lights on dash
- Audi Newbie. Hello
- Gearbox Malfunction!?
- Audi A4 B8 issues
