2.7t early engines = trouble?
I'm looking at two A6 with the 2.7t,( i totaled my last car it was a mercedes 300sdl which had a turbo as well but it was a diese) a 00 and a 01, reading some of the blogs im wondering if they worked out the kinks with the engine by 01? Also only 18 so what would the maintence cost be like on it?
I didn't know there was much difference between the 00 and 01. The most important point is to respect the turbos; be easy on boost until the oil is warm and use good oil. My 2000 has 110k+ and has been a good engine so far.
if you are worried about maintenance costs, then this car is NOT for you.
'01 *should* have the larger oil lines to the turbo
Originally Posted by quickaudi:STFA
(Post 23890602)
wfedwar how much do you spend yearly in maintence out side of oil and bulbs etc
Originally Posted by tyrusbeaucher
(Post 23891683)
Also search around there's a ton of threads covering this.. |
right, which is when they swapped over. the '00 had stuff made in '99.
